Thread: additional pieces
    Apr 2015
    New Bedford, MA
    65
    additional pieces
    Just got my 2800 gph intex krystal clear pump and I noticed it didn't come with plunger valves..is there anything else I need to purchase?
    summer scape metal frame AG pool 14x42, 3750 gallons
    INTEX Krystal Clear 2800 GPH sand filter pump
    TF-100 Test Kit Pool Calculator , cya-chart
    Pool school,recommended-levels
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: additional pieces
    They do not come with plunger valves. I ordered mine from Intex when they were in stock.
    Many have used ball valves to build their own.
    You can survive without then
    M, but it makes it much harder to clean the filter basket on the pump. I found some caps I was able to screw on to keep the water from gushing out. I screwed them onto my outlet and inlet. It was a huge pain though and it is much better with the plunger valves now.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Apr 2015
    New Bedford, MA
    65
    Quote Originally Posted by Azgirl71 View Post
    It looks like I also need the nozzle assembly as well
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Those you can get on Amazon. Get 2 of these and just unscrew the eyeball from one. That is what I did.
    Amazon.com : Intex 1.5 in. Large Pool Inlet Nozzle Assembly : Toys And Games : Patio, Lawn Garden
    This thread will help with the install.
    Cutting Larger Intake Return holes in your Intex
    Lisa
