Thread: White Cover for Solar Pool Cover
    Apr 2015
    South Central PA
    297
    We moved into a house with a pool in November. I have a solar cover with a reel to take the cover off when using the pool. I was reading the literature that came with the solar cover, and it says to cover the solar blanket with the white polyethylene cover that came with the solar cover to prevent the sun from damaging it while it's rolled up. This white cover is so thin that it's starting to shred and won't be able to cover the roll too much longer. I checked at Lowe's and Home Depot, but the only have clear and black In the paint drop cloth section. I also did an online search and nothing really came up. Does anybody know where to get a large sheet of white polyethylene? Does anyone not cover their solar cover when rolled up?
    Thanks
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: White Cover for Solar Pool Cover
    It's just to keep the Sun's UV rays off the cover. Anything that blocks it will work. I think they used white to reflect heat. Go see what kind of cheap tarps they have at Harbor Freight.
    Apr 2015
    South Central PA
    297
    Thanks!! I forget about Harbor Freight because there's not one too close, but I have family coming this weekend and there's one near them. I found a reflective silver one on their website that should work well.
