Results 1 to 17 of 17
Thread: SLAM process prevails yet again!! (Pics)
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Just wanted to post some pics to show how much better the TFP method is over the pool stores. This is my step-daughter's pool and she had been having a pool guy from a local pool store coming to try and open her "swamp". After almost a month her pool was still green. So I stepped in with my TF-100 testing kit and a whole lotta bleach and I'm proud to say the pool is now clear after only 2 days! Here's the pics that tell the story:
    This is how it looked in the very beginning on May 1st:
    This was on May 3rd after the pool guy came by (he was using shock):
    May 5th:
    May 6th (pool guy still, but he's making a little progress):
    May 7th:
    So the pool guy keeps coming and the pool never looked much different, continuously staying green. By this time I've advised my daughter to stop using him and start pouring bleach in the water. This scared her and the pool guy tells her by no means should you ever use bleach. Needless to say the pool never cleared up and my daughter is finally fed up. I go to her house to start the SLAM and finally get this water clear for her. Next post . . .
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: SLAM process prevails yet again!! (Pics)
    Glad you took over! Looking forward to next post.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    This is how it looked when I started on May 28th:
    This is what I used (along with lots of vacuuming and sweeping):
    May 29th:
    This is today, May 30th after only 2 days!!! Clear water and you can see all the way to the bottom!
    ​Jennifer
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    I do believe that's the drain I see all the way down there in the deep end! Yay!!!! Thanks TFP! My daughter now says I'm the pool doctor! Gonna do an overnight chlorine loss test tonight and more vacuuming today but I do believe we are there!!!
    Sorry my pics are sideways. Can't figure out how to rotate them on my phone.
    ​Jennifer
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thank you for sharing!
    Lisa
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    There you go!
    Divin Dave,
    Jun 2014
    15,226
    Another thumbs-up for the TFP method! Great job to you JLS. Thanks for sharing.
    Quote Originally Posted by *JLS* View Post
    .... the pool guy tells her by no means should you ever use bleach.
    This is always hilarious. The pool stores tell you "never use bleach", but they'll happily sell you "liquid chlorine" or "liquid shock", which is, of course, just more concentrated bleach.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Make sure you get her to stay on board and not just run back to "their" ways.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by TomBorg View Post
    As long as it says shock on it instead of bleach they can endorse it.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Thanks everyone! Thanks to TFP I've never had green water in my own pool. Needless to say i was excited to finally get to try the SLAM on my daughter's pool after reading about everyone else's success stories. I love a good challenge and TFP helped me clear this one with no problem!!
    ​Jennifer
    i_hate_pools's Avatar
    May 2015
    coal city il
    27
    I cant believe a professional pool guy leaves all that **** on the bottom and thinks its going to clear up
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Quote Originally Posted by i_hate_pools View Post
    My thoughts exactly! And this is even better - the pool guy had been at her pool the morning of the day I went to start the SLAM. When I tested for FC it was at 0! I'm convinced all he did was sit there and try to talk the algae out of the pool. Haha
    ​Jennifer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    "Professional" just means he does it for a living, not that he's any good.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Quote Originally Posted by n240sxguy View Post
    I'm going to order a TF-100 for her and be sure of this! I don't think she'll ever step foot in another pool store, I've created another believer in the TFP world!
    ​Jennifer
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Schweeet! Good job!
    Casey's Avatar
    SW PA
    10,457
    Done good!
