Thread: Test Results using my test kit.
    May 2014
    Alabama
    5
    Hello,
    Just finished up testing my pool. The water is very clear.
    I believe I need to raise my CYA a bit but wanted to get opinions from more knowledgeable folks first.
    Thanks!
    PH 7.5
    FC 6
    CC 0
    CH 100
    TA 90
    CYA 50
    Pool Constructed: 8/2013 20x40 Vinyl 32.5K gal IG - TF-100 Test Kit
    Hayward Pro Series S244T Sand Filter and Tiger Shark
    Hayward SuperPump 1HP
    Hayward Gold Line Aqua Plus Control
    Hayward T-Cell-15 SWG
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Test Results using my test kit.
    Greta numbers! Yes since your pool is clear and maintaining FC with 0 CC and you have a SWG you want to raise your CYA to 70-80 range.
    Use pool math to calculate how much Stablizer you need. Add it to a sock and set it in top of a skimmer or ties it in front of the return jet. Leave pump running until it disolves. You can speed the process by queezing the sock. Once it is disolves remove the sock and test CYA in one week.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    How long are you running the pump and SWG?
    The reason I ask is because those numbers look good. Raising CYA might allow you to turn down the SWG% or the pump run time. On the other hand, if you're doing that well with only 4 hours pump and 50% SWG, why mess with success?
    May 2014
    Alabama
    5
    I have it currently set to run from 7:30am to 7:00pm @ 40%.
    I live in the country with a big hay field surrounding my house.
    My thinking may be warped but I like running the pump during the daylight hours to keep bugs/grasshoppers/crickets and blown hay particles etc.... gathered up in the skimmers.
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    That is what I do, run my pump on 1100rpm (150w) a lot to skim all the tree stuff of the surface before it sinks. My SWG is on a separate timer.
