Thread: Need help wireing a PB4-60 booster pump
    May 2015
    Florence, sc
    1
    I have new PB4-60 booster pump and need help wiring it? There are connections inside numbered and I have power wires black,white and ground to connect. I know where the green ground goes but what about the other two? I lost track when I took the old one loose!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Need help wireing a PB4-60 booster pump
    I assume it is 120v based on the white and black, but that's a dangerous assumption to make. Can you verify?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
