Results 1 to 11 of 11
Thread: adding extra strainer and flow valve s to agp.
    I'd like to add an extra set of strainer and flow valves to my intex pool. do I need to reinforce the holes prior to putting the valves on?
    I have a separate pump that runs my solar panels. I'd like to keep the two systems separate.
    Thank you
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: adding extra strainer and flow valve s to agp.
    I would reinforce before adding them. You could probably use a patch kit to add an extra layer where you will be cutting.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here's some videos that people have done:
    Pretty detailed info: Installing a thru-wall skimmer in an Intex pool - YouTube
    Intex pool wall skimmer install - YouTube
    Looks like they just mounted it. Looks good.
    Good idea with the patch kit. I may reinforce the edges of the holes with the patch kit. Or glue the patch kit to double up the liner then cut the liner .
    Thank you
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome.
    Lisa
    May 2012
    Baltimore, Maryland
    183
    If your pool has the intex installed drain plug at the bottom of the pool you can use that and 1in pvc for plumbing.
    I use the bottom drain for my solar. Its hooked up using the 1000gph intex pump and hoses attached with some 1in pipe and fittings.
    My sand filter is plumbed with the larger intex valves which I cut in. The area I cut for the larger valves were already reinforced tho.
    I saved some liner from previous pool for patching and or reinforcement
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
    That's a fantastic idea. Did you use a certain valve in the inch drain plug? I could use one as intake one as flow valve?
    May 2012
    Baltimore, Maryland
    183
    Ill take a picture it will better explain it.
    Thank you kindly.
    May 2012
    Baltimore, Maryland
    183
    http://www.troublefreepool.com/threa...pump-for-solar
    I dont remember my photobucket sign-on at the moment. although I did take new pictures. the ones in my thread above are much better
    where the connection is made at the pool the pcv consists of a 1inch section, the 45 elbow then some more pipe the valve and more pipe again. where it hooks onto the pool is a adapter that was inside one of my smaller intex filter hoses it slides snug over the 1inch pipe and is hose clamped, where it is hooked onto the pool fitting there is a piece of rubber from my old strainers and the adapter over that with a hose clamp. hopefully you get the idea. The small intex hoses slip over the pipe without any adapters just used hose clamps
    Very ingenious!
