Thread: Light Soap Bubbles Every time Surface is Broken
    Hi All,
    I have a very very small amount of what looks like soap or foam bubbles when anyone jumps in or water from the return lines breaks the surface of the pool. They disperse quickly and the pool chemistry is good. Any thoughts?IMG_1409.jpg
    Robert
    Gunite. 14,869 Gallons. Hayward cartridge filter. Hayward Super Pump 1HP. Chlorine.
    Baltimore, MD
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Light Soap Bubbles Every time Surface is Broken
    Got any test results? I think I've read low CH can cause foaming. May not be related. Have you used any magic potions that could cause it? Maybe just sunscreen or something.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by RSAnative
    ...the pool chemistry is good.
    A full suite of test results would confirm that.
    Other possibilities for the foaming...Air in the return lines, use of bleach with "thickeners" or labeled as "Easy Pour".
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Have you put any algaecide in your pool? It can also be caused by air in your lines.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Aug 2014
    Shallotte, NC
    693
    Easy pour bleach?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by ewkearns
    Easy pour bleach?
    Yes, some bleach that contains added thickeners is labeled as "easy-pour". WalMart's Great Value brand uses that labeling, Clorox uses "splashless". These contain thickeners that can cause foaming in pool water. This is why we recommend plain, unscented liquid bleach without any thickeners.
