Thread: I need help!!
    May 2015
    Harrisburg/ PA
    4
    I need help!!
    I have a 12' x 24' above ground rectangle pool. I have a solar cover that I want to take off without all the neighbors help! LOL
    I want to make a reel, any suggestions?!?!
    Thanks!!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: I need help!!
    Welcome to TFP! I'm sure someone will be along shortly that can offer some advice on this.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: I need help!!
    Welcome to TFP!if you use the search box you will find there are quite a few above ground cover reels that members have built with PVC
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
