Thread: Hayward 250 heater problems
    May 2015
    MONROE/ MI
    1
    Our heater runs however the "up" temperture set button on the digital display will not increase over 80. The down arrow will work as well as the mode button. How do I fix this? thanks
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hayward 250 heater problems
    Welcome to TFP!
    This may be a factory default setting. Since 80F water is hardly what I would consider to be scalding, I would think there is a way to override this. Check the documentation that came with the heater. If that doesn't give any clues, then I would it or see if anyone else has experienced this issue with that particular heater.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Which model of Hayward is it that you have?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    This is strange. I also would like the model.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
