Results 1 to 8 of 8
Thread: Brown Spots on bottom of above ground pool
    May 2015
    Smyrna, TN
    5
    Hi. Glad to be here and have already read a lot of things that help me. I have had my pool open for about a month now and the chemicals have been in balance. The other day I noticed that there was a brown spot on the bottom of my pool liner. I didn't think much about it because I thought it was just dirt. Well, then yesterday I noticed there were about 4 more brown spots on the bottom. Not algae because I keep it treated. I tried to scrub the stains but that did not work. I thought I would ask for suggestions here before I take a sample to the pool place. I've had the pool for 8 years and this is the first time I've had this problem although ever since I started having my yard fertilized, I've had other problems. Any advise will be greatly appreciated.
    May 2015
    Mount Cheaha Alabama
    250
    Re: Brown Spots on bottom of above ground pool
    Any other details of the pool surroundings?
    How big is the spot? Algae can grow from beneath the liner and stain the surface. You can rub citric acid tablets on the stain or set a chlorine puck on it for an hour to see if it goes away.
    I get little brown spots on mine from undeveloped acorns breaking free this time of year.
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    May 2015
    Smyrna, TN
    5
    I have a large deck and Leland Cypress trees along the side of the pool. Is there any way to remove the algae growing under the pool liner? I don't have any citric acid tablets but I will try the chlorine tablet.
    May 2015
    250
    Quote Originally Posted by Cindyh5161 View Post
    Try the puck first and see how it goes.
    Citric acid can be sourced in powder form near the canning section of most grocery stores, pour it in an old sock and scrub like a sponge.
    Once algae is under a liner not much you can do to get rid of it. Bringing your free chlorine level up to SLAM levels(dependent on CYA level) may beat it back.
    My last unconventional method I will share as a last resort if the above does not help you
    May 2015
    Smyrna, TN
    5
    Thank you! I will give it a try and let you know how it goes. I really appreciate the feedback.
    May 2015
    Smyrna, TN
    5
    O.K. I tried the chlorine tablet and it seems to be working. What does that mean? While it's sitting on the stain there is this slimy stuff (kind of like snott - not to be gross) floating up and around in the pool.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Hi Cindy,
    what this means is that the stains are organic in nature. The slimy stuff is called biofilm.
    Most likely the spots are some type of algae (there are 1000s of them) but certainly it is organic in nature and the appropriate chlorine treatment will take care of it.
    The cure for this is to SLAM the pool. It is not a one time thing, its a process and it works. To do it, you will need to test the water yourself. You will be testing multiple times a day and adding liquid chlorine multiple times a day.
    Either the TF100 or the Taylor K2006 will be an acceptable kit. The Taylor can be gotten at multiple places on line. You most likely will not find it in a pool store.
    The TF100 is only available online. Since your in TN, the best place for you to get it is at TFTestkits.net . The TF100 is the best bang for the buck.
    Instructions on how to properly slam as well as other needed links and info below.
    Pool School - SLAM - Shock Level And Maintain
    Pool School - Chlorine / CYA Chart
    http://www.troublefreepool.com/calc.html
    Divin Dave,
    May 2015
    Smyrna, TN
    5
    Thank you. I will get on it.
