Thread: Hello from Central Maine...
    May 2015
    Madison/Maine
    1
    Hi. New to the forum and have learned a lot already, Thanks!!
    27' Radiant-20" in ground, bottom dished 10", Pentair Dynamo 1HP/Composite pump, Pentair sand filter with 75# Zeosand
    Pump located 12' away below water surface.
    Maitronics Dolphin Supreme M4
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hello from Central Maine...
    Welcome to TFP!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Papermaker!
    Good to hear. I pick up something new here every day myself. Good to have you aboard.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP. I haven't seen many folks from Maine here.
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Hello Papermaker24,
    You have to be living in the middle of a dream where you are - I am envious (and in about one month, even more so as we suffer through another miserable summer..)
    This is an excellent resource and it has helped me drastically cut my chemical bills. Welcome!
    20K gal, IG vinyl, Waterfall on 2nd pump (1HP US Motor), Dolphin cleaning system, Central Arkansas, installed 1999
    2 Haywood Super Pumps, 1HP (main and waterfall pumps), Purex Triton II (TR 60) Sand Filter (replaced original 2016)
