Page 1 of 4 1234 LastLast
Results 1 to 20 of 65
Thread: Think it's time to take back my pool...
    May 2015
    Indianapolis, IN
    50
    Moved in a year or so ago right at pool opening. Prior owner was from family that owned pool business - water was in great shape at opening (crystal clear) - stayed very stable for couple months just popping a few pucks in chlorinator every week. I didn't have time to learn so I was paying pool guy $35 for weekly visit.
    There were some iron stains on the bottom of the pool (gunnite). Was advised we needed to lower the chlorine so he could treat them. Took almost a month for FC to drift down to zero from 5. Then pool guy treated for metal stains, which didn't really work, and the water has never been right since.
    Water was cloudy for probably a month - finally got clear right at end of season. I have old invoices showing FC was regularly between 0 - .5 and CC was .5 - 2.0 during this time. Closed pool with FC at .5, CC 1.0, TA 120, CH 300, CYA 85 (don't trust his CYA #'s as they jumped around a lot week to week and now I know that was highly unlikely). The pool was clear at the time of closing after a lot of expense from him throwing in bunch of chemicals in the last 6 weeks of the season (Hmm, he mentioned he used to work for Leslie's....).
    Opened pool and it was cloudy. Could see maybe 4ft down and it's a sport pool that's 6ft deep in middle.
    Opening values from pool guy were:
    5/12/2015
    pH 7.6
    FC 0
    TC 0
    CC 0
    TA 310
    CH 430
    CYA 0
    Pool guy notes: added 4 gal LC and 1 gal acid
    5/21/2015
    PH 7.2
    FC .5
    TC 4
    CC 3.5
    TA 270
    CH 360
    CYA 0
    Pool guy notes: Added 5lbs granular chlor. 6oz Clear and Perfect. Please add 4 Gal LC between visits.
    5/28/2015
    PH 6.9
    FC .5
    TC 4
    CC 3.50
    TA 240
    CH 380
    CYA 100(?)
    Notes: Pool was clearer but not 100%. I had hit it with 4 gal LC between visits as instructed.
    Pool guy notes: Added 4 Gal LC and 8lbs soda ash
    Pool is currently hazy - regressed a bit from 5/28 pool guy visit. I got frustrated and bought a lot of LC and some test strips. Realized pretty quick those strips are not accurate enough. Tonight I did some digging in pool shed and found a Taylor K-2006 test kit that previous owner left for us (Yes!).
    I played around a bit today with LC and test strips and then the K-2006 kit. I won't bother with all the strip results, but after adding in 4 gal of 10% LC in AM and 4 gal 12.5% LC at lunch, and 4 gal 12.5% LC after work, the strips were still reporting low TC and FC.
    Here is my first result with the K-2006 kit from 9PM tonight:
    PH 7.0
    FC 1
    CC 4.0
    TA 260
    CH 400
    CYA <30 (I filled up to top of tube and could still faintly make out the black dot). Did the test twice to verify.
    Thoughts on what to do next? Is SLAM needed since my water is only hazy? I can currently see main drain at bottom (6ft) but just barely - see picture.
    Pump runs 24x7 during the season. Filter has never been backwashed (don't know how to do it). Pool guy reports filter pressure readings as "good" every week.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Think it's time to take back my pool...
    Welcome to TFP! That is a great idea!
    First bring PH up to 7.2, it might take a few tries because you are at the bottom of the scale. I would SLAM after the PH is at 7.2 and add 10ppm of CYA and assume it is 30 unless a test says otherwise, just to be on the safe side. It won't take long and it will get you nice and clear and all set for summer.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I would order new chem's for your k-2006.. who knows how long they have been in there and may be giving you wrong info, they usually last 1 to 2 years...
    The reason I say this is if they were using trichlor or dichlor for who knows how long your CYA is probably higher than what is being reported.. If it is under 30 that is awesome..
    you can order all fresh chem's from here TFTestkits.net
    May 2015
    Indianapolis, IN
    50
    I'm thinking before I start a SLAM, I'm going to run to aquarium store and get an ammonia test. I was reading some other threads and makes me wonder if there is ammonia in pool since cya is not registering on my test kit (or strips) and the pool seems to have this insatiable demand for FC.
    20x40 gunnite sport pool - 26K gallons / Pentair chlorinator / Pentair SF-N1-1A 1HP Pump / System 3 S8M150 Filter / Auto-cover / Paramount In-floor Pool Cleaner / Taylor K-2006
    May 2015
    Indianapolis, IN
    50
    Don't disagree reagents could be old, but going to continue for now with what I got until I get new ones. My results were somewhat close to my pool guy's numbers (though he did not record cya reliably). The pool shed is part of the house so temp wise it was stored in cool/dark place. The kit appears to be brand new.
    Jun 2014
    15,253
    Slowrider5, pooldv and cowboycasey have rock-solid advice. Cloudiness means something is brewing and it will only get worse. Checking for ammonia won't really solve anything since the TFP recommendation will most-certainly still be to start the SLAM by using regular bleach. If there's ammonia in the pool, the SLAM might take a little longer, but it will still work. Fresh reagents for your K2006 are a good idea, and many of us also use the TF-100 and are very pleased with its results. Best investment I have made for my pool and paid for itself MANY time over. Hang in there and give the TFP method a try. You should be quite pleased with the results. Remember to keep a close eye on your "Recommended Levels" and "Chlorine/CYA chart" comparisons as noted in the links below. Good luck, and have a nice day.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    I assume you are firing the pool guy? No one who comes once a week and doesn't really care about your pool will ever do as good a job as you will, looking after it daily. With your new source of knowledge here at TFP you can save loads of cash doing it yourself, and taking pride in a job well done. Welcome to TFP!
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    May 2015
    Indianapolis, IN
    50
    Want to check the ammonia first, because I want to have a rock solid understanding of the problem before I start, even if the end result of a slam is still the same.
    Plus, since I live in a area outside of town it takes quite a while round-trip to head to the store and back, so I want to better feel of just how much bleach I might start off with.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Before you use your ammonia kit I would like to ask you to run an FC test. If it is 0 use PoolMath and raise it to 10ppm, wait 30 minutes and test again. Report the results of the second test to us.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Indianapolis, IN
    50
    Ran test using .2ppm multiplier for better granularity. .4 FC. CC was 4.
    The Hayward chlorinator is on and there are two floaters in the pool as well. Perhaps that is the only thing that has kept it from going all the way down to zero
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by Slowrider5 View Post
    The way the FC plunged and the CC jumped when you added the first 4 gallons of bleach pretty much confirms ammonia in my mind.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Richard320
    I'll second that.
    I would do a SLAM with one modification...Hold off on adding any CYA until chlorine begins to hold. Add FC to 10 ppm and retest every 30 minutes & record your results. Dose FC back up to 10 ppm as needed after each test. Repeat the 30 minute tests until FC is at 4 ppm. At that point, we can say that chlorine begins to hold. Then add CYA back into the pool, targeting a level of 30 ppm. Increase the SLAM FC target to 12 ppm and complete the SLAM as directed in the article until the criteria of "Done" are met. At this point, there is no longer a need to test FC every 30 minutes - just follow the SLAM guidelines for testing.
    May 2015
    Indianapolis, IN
    50
    Ammonia positive. 2ppm - maybe 3ppm but definitely at least 2ppm.
    May 2015
    Indianapolis, IN
    50
    Modified SLAM has begun....keeping cover closed in between checks and doses to avoid sunlight loss.
    4:30 PM Started at .4 FC (assumed it was still here since it had been .4 for a couple readings earlier in day)
    5:00 PM 3.2 FC / 2.2 CC
    5:30 PM 6.2 FC / 1.6 CC
    6:20 PM 9.6 FC / 0.8 CC / Started Adding CYA with measured amount of dichlor
    May 2015
    Indianapolis, IN
    50
    7:15 PM 10.0 FC / 1.5 CC / Ammonia re-check - down to .5
    8:00 PM 11.5 FC / 1.5 CC
    8:30 PM 13 FC / 2.0 CC (checked it a little soon but was leaving house for upwards of 2 hours)
    10:10 PM 7.0 FC / 2.0 CC
    11:20 PM 11.5 FC / 2.0 CC / 30-35 CYA (tough to see in the dark - I came inside house to look at it in a lit room).
    Dosed it a little higher to 16 for the overnight. On the SLAM page it says you can turn tablet dispenser back on to help maintain FC levels, so I turned the dial to 3.
    I noticed filter PSI was reading 32, that seemed higher than I recalled seeing it but never paid much attention in the past. Checked old pool guy invoices - most of last year was around 20. All my invoices from this year only report "good/OK" so I don't know what it has been so far this year.
    Overall I suppose things seem to be according to plan and within what I was expecting based on everything I read. Biggest questions I have are why would CC tick back up and is filter PSI a concern? Comments welcome.
    May 2015
    Indianapolis, IN
    50
    First reports of Day 2
    8:00 AM 2.5 FC / 1.0 CC
    9:45 AM 10.5 FC / 1.5 CC - Ammonia re-check - down to .25
    11:10 AM 11 FC / 1.0 CC
    1:15 PM 8 FC / 1.0 CC - Ammonia check - still .25
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    From what I understand keeping your pool covered all the time will slow your progress. Exposing your pool to sunlight will help with breaking down CC and allow the pool to outgas.
    If normal pressure for your filter is about 20, and it's now 32, I would backwash.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    May 2015
    Indianapolis, IN
    50
    Update....
    3:00 PM 11.5 FC / 1.0 CC
    4:50 PM 10.0 FC / 1.0 CC
    6:40 PM 10.5 FC / 1.0 CC - Verified CYA is 30-35 (I'd call it 32)
    May 2015
    Indianapolis, IN
    50
    Definitely improvement in clarity since when I started - tough to see in original picture but I uploaded before/current of the steps on the side that help to show additional clarity.
    Definitely improvement in clarity since when I started - lighting wasn't good on comparison to my original straight-on picture so I uploaded before and current of the corner steps that help to show additional clarity.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    19,067
    You added steps!
