Results 1 to 10 of 10
Thread: Tested my buddys pool, help us get it back in action.
    Apr 2015
    Waterford, MI
    133
    My buddy has been having pool issues. I took the tf-100 and ran the tests...
    Cl= 0
    Ph = 8.2
    Ch = 500+
    TA = 190
    Cya = 0
    Salt = 1200ppm
    24" AG, 13500 gallons, cartridge filter, ionizer.
    I told him to add 4g of liquid chlorine and 6lbs of stabilizer. Didn't tell him to get muriatic acid, but I think I should have.
    Hes going to get a chlorine test kit (eventually a tft kit), and try and maintain the chlorine up. Still not sure how high to maintain it.
    Advice please and thank you.
    Michigan - 24'x54" AG, approx 15,000g, 2 center drains, Cartridge filter, Aqua Pro 2hp, 2 speed pump 3.5a@1725w / 10.5a@3450w, AquaCal TropiCal T90 heat pump, Hayward Salt & Swim SWG, Poolskim, Aquabot Rover Jr.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Tested my buddys pool, help us get it back in action.
    Is the water green? Clear? Cloudy?
    If it isn't clear he probably needs to SLAM - Shock Level And Maintain the pool.
    6lbs of CYA will raise the level to 53ppm. Use the Chlorine / CYA Chart to find the chlorine level for 53 CYA.
    Apr 2015
    Waterford, MI
    133
    Its cloudy. If he slams and has zero CYA, should he slam to an FC of 10, while trying to build up CYA?
    As CYA increases, increase FC according to the cl/cya chart?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Once he adds the Stablizer to target 30 and it is dissolved and brings the PH down to 7.2 he can SLAM to 12
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    DFW, TX
    24,483
    Most of the CYA will be available within 2 days. As AZ says get PH to 7.2 and SLAM assuming CYA of 50.
    Apr 2015
    Waterford, MI
    133
    Should he wait 2 days to add bleach?
    May 2015
    Central Illinois
    41
    You should not allow the FC to be zero for any reason. What was the result for CC? He needs to get the FC up quickly.
    Viking Maui 2300g fiberglass in ground pool in a screened room with polycarbonate roof. 45gpm pump with sand filter manually chlorinated. Entire pool water can cycle in 51 minutes. Jacuzzi 336g hot tub with ozonator, manually chlorinated. TF 100 test kit with speed stir. Fungi pronounced Fun Guy, I'm Jim
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    No, have him target at 2-4 for FC until the Stablizer is dissolved. Then he needs to target the level for the CYA you targeted.
    Lisa
    May 2015
    Central Illinois
    41
    Sorry I meant "up quickly" from zero. Good advise Lisa.
    DFW, TX
    24,483
    I would start SLAMing right now. Here is the process, Pool School - SLAM - Shock Level And Maintain
    In general pool maintenance you should never let the chlorine level drop below the minimum level for the CYA level or algae will start to grow, Pool School - Chlorine / CYA Chart
