Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: 2 pumps in 2years...need recomendations.
    Apr 2014
    Dallas,Tx
    13
    Long time lurker, first time poster. First this is a great forum and appreciate the information I have already learned.
    Now a quick synopsis of my situation. My wife and I are first time pool owners and this is a learning process. We recently lurched a home with a pool (10yrs old) in 11/2013. Home was a foreclosure and bank getting the home ready for market purchased a new pump in 5/13. Our offer was accepted and during a pre-purchase inspection noticed pump was making noise and was replaced under warranty in 12/2013.
    Around December 2014 the pump began to make noise but had not impact on performance. In the last 2 weeks it's been losing pressure despite a a clean DE filter, no clogs, air leak, etc. It will run fine but within 1-3hrs water pressure is very low, very little coming out of sprays and water features.
    So I'm considering a replacement motor but hesitate with since short life span. I'm pretty mechanical but cannot figure out why they failed so soon. Only then I noticed was pool company did not bolt pump to slab.
    Also considering a variable speed pump.
    Any help will be greatly appreciated.
    Inground gunite 15,000gal with water fall spa, US Motors Ecotech variable speed 3hp pump, chlorine 6lb DE filter.
    30,426
    Re: 2 pumps in 2years...need recomendations.
    Welcome to the forum.
    Is the pump running now? If so, what kind of noise is it making? Is it keeping your water clear?
    Are you asking for suggestions on a new pump?
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Some noises are easily fixed, some aren't. What is it you're looking to do with yours? Fix or replace?
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Apr 2014
    Dallas,Tx
    13
    Quote Originally Posted by PoolESQ View Post
    Sorry, only part of the post was posted...I edited OP
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Did they replace the whole pump or motor? If it's squealing it could be bearings. Are you comfortable checking the impeller or obstructions/trash/debris? Depending on your energy cost less than $.30 KWH a 2-speed motor/pump my be more cost effective.
    Apr 2014
    Dallas,Tx
    13
    Quote Originally Posted by bobodaclown View Post
    They only replaced the motor. Should I replace the front part of the pump, it looks brand new?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Pump motors should last 10 yrs or more if properly maintained. The wet end should last much longer.
    So I would replace the motor but you should figure out why they are failing so soon. Was the motor leaking prior to failure?
    If you having bearing problems in might be the seals that are failing first. Once the seal fails, it will start to leak water and usually on the motor bearings. This in turn rust the bearings and then the motor fails.
    Mark
    Apr 2014
    Dallas,Tx
    13
    Quote Originally Posted by mas985 View Post
    That is most concerning, the short life span. Only thing I can think of is when they replaced the motor they did not replaced the seal and it leaked causing bearing failure. Currently it sounds as if the bearings are failing.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Or they did not install the seals properly which is not uncommon. Another possibility is that they used a rebuilt motor which usually doesn't last as long as a new one.
    Mark
    Apr 2011
    Murrieta, CA
    2,360
    Ding ding ding. I think we have a winner. Reusing seals it's penny wise and pound foolish. Always replace shaft seal with motor.
    Apr 2014
    Dallas,Tx
    13
    It's a rebuilt unit if I had to guess, and most likely reused the seal.
    Apr 2014
    Dallas,Tx
    13
    This my guess, during disassemble I noticed the bolts holding the motor to the front strainer basket were only hand tight. This is why I think water was getting in along with the seal.
    Is it worth trying to change the bearings or cut my losses and buy a new motor?
    Apr 2011
    Murrieta, CA
    2,360
    Depends on if you have more time our money. Check out you tube. There are lots off videos on the procedures. What's the condition of the housing?
    Apr 2014
    Dallas,Tx
    13
    Thanks for he info, can you recommend a variable motor only with a square flange?
    mas985's Avatar
    Pleasanton, CA
    11,741
    A variable speed or two speed motor? Personally, I wouldn't go with a variable speed replacement motor. They seem to have more issues than a new VS pump.
    Mark
    Apr 2014
    Dallas,Tx
    13
    I guess whichever offers the best value in savings and most dependability.
    I'm buying a new motor, figured why not opt for energy savings as well.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Well a two speed would give almost as much in energy savings as a VS while I have not been too impressed with the VS add on motors. If you really want a VS, then I would go with a new one.
    Mark
    Apr 2014
    Dallas,Tx
    13
    mas985's Avatar
    Pleasanton, CA
    11,741
    That is a full rated motor. Is your 2 HP a full rated pump or an up rated pump? Do you have a pump model# or a service factor off the old motor?
    Mark
  20. Back To Top    #20
    Apr 2014
    Dallas,Tx
    13
