Thread: Pump Silent - Won't Start
    Digital_Kitchen's Avatar
    Nov 2014
    Dallas, TX
    3
    Evening All
    Having a strange issue with my pump. It's been working just dandy until today when I tried to turn it from "Auto" to "On." I usually leave it on "Auto" all the time, and saw it running several times this week (could see the water feature/fountain in the spa).
    But today, the water was starting to look a tiny bit hazy (probably from this non-stop rain we've had in Texas for the last several weeks). When I toggled it from "Auto" to "On" nothing happened. No hum like other people mention in non-starting pump issues. There was no audible sound at all.
    So I started to do some research for trouble shooting, and found to try:
    -Turning the shaft via the back of the pump
    -Turning the impeller by hand on the front of the pump (by the leaf basket)
    -Toggling the breaker switch off/on, did that twice.
    -Inspect inside the pump panels.
    Everything seemed normal. The shaft turned very easily, and seemed very well lubricated. The impeller also turned 360 degrees several times without impedance. Wasn't much to see in the two panels I opened, just some wires under one, and I suppose a capacitor under the compartment on the top? (guess on that).
    The final time I tried to cycle it to "On" I did hear a very audible "puff" - almost like an airblast, which wouldn't make sense, so maybe a fuse? Never saw any fuses in the two panels I opened, and I sniffed all around the pump and couldn't smell that tale-tell burnt electric smell, so no idea what that final "puff" was.
    Anyways, any thoughts or ideas?
    12,000 Gallons - Chlorinated with Bleach
    Pebble & Plaster Construction
    Spa with Fountain & Waterfalls into Pool
    Pentair FNSP 48 DE Filter
    AD Smith Centurion Pump
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Pump Silent - Won't Start
    Was the motor warm/hot at all? Did you take the back cover off? I assume that's where you saw the wires? There should be a centrifugal switch the makes the contacts for the start capacitor. Make sure it is pressing the contacts and moves freely. I would guess it's either that or the capacitor is bad.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
