Thread: How long to vacuum after liquid stabilizer?
    May 2014
    Trenton, NJ
    24
    I added liquid stabilizer to my pool last night (Thursday) around 9:30pm. I had to put all new water in my pool and added a whole bottle of liquid stabilizer. Am I safe to vacuum and backwash Saturday morning? I know it says to wait a week for granular cya, but does the same apply to liquid? Thanks!
    15'x26' above ground pool installed on 5/10/14, 1 hp -Hayward pro series sand filter (Model # S166T92STL), Hayward Vari-Flow valve (Model # SP0714T1), Hayward Power-Flo Matrix pump (Model # SP1592TLFP). TF100 test kit. Diver Dave automatic vacuum.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: How long to vacuum after liquid stabilizer?
    Quote Originally Posted by Ktooch11 View Post
    Yes, it is fine to backwash, especially if the pump has been running plenty to mix it in. You only need to backwash when the pressure rises 20-25% above the clean pressure.
