Thread: De backwash valve stuck?
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    At the bottom of my filter is the backwash plug. 3 years ago I replaced that with a ball valve and hooked a backwash hose to make it easy to backwash. Shut off pump, open air valve, bump, open backwash valve to dispose of dirty de. Run pump for a little to clear extra gunk until water runs clear. I have done this for years. This year I had trouble opening the valve for backwash. I didn't force it so I got a pair of pliers and slowly tried to move it. It broke off and then 5 hours later after struggling to remove a broken valve bought another and replace it. Smooth sailing, I thought... Until I just tried normal backwash procedure and it is stuck again!!! What is happening !!!! Should I loosen bolts on filter ?? If I break another I will lose my mind.
    17x32 Legacy Pool / Deck built around entire pool / Hayward EC40C92S Perflex 1-Horsepower Extended-Cycle D.E. Filter / Dolphin DX-3 / GLI Cyclone Solar Cover Reel / TF100 Test Kit/Raypak 266k BTU Cupro Nickel Gas Heater
    Pool/Deck Install Finished Finally!!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Re: De backwash valve stuck?
    I just fixed it. Incase anyone was wondering or maybe if someone has this problem in the future I will post the simple fix below.
    Apparently when a lever with a ball valve is too tight and it won't turn with your hand or with an easy tug of a wrench (with the handle off obviously) all you need to do is loosen the hand tighten junction piece that is connecting the two parts slightly, maybe 1/8 of a turn. I had it too tight so there wasn't enough give to let the ball valve open and properly backwash the filter. Basically, I am too strong lol!
    I also like to think that the pool gods smiled on me here because I just ordered my tf100 kit today.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Cheap ball valves swell over time, this is why we suggest using the neverlube style pool valve
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Quote Originally Posted by Isaac-1 View Post
    Thanks for the info- they look great.
