Thread: Opened Pool Today, Heater Drain Plug is leaking like crazy
    Mar 2012
    Cincinnati, OH
    62
    Hired a new company to close the pool last year. I had a heck of a time finding where they placed the drain plug to the heater, but I finally found it. I put teflon tape around the threads and screwed it in. Once the pool was fired up, water started pouring out where the drain plug is installed. The plug is from a Raypak 266A heater. Does anyone know if this plug is supposed to have a gasket on it, or any idea why it is leaking? It is two years old and has never leaked. Really appreciate your help, as I can run the filter this leak.
    18k, 2001 Ft. Wayne 18'x36' oval sport pool with polymer walls, IG, vinyl, 3.5' at ends and 5' in center, Pentair 1 1/2 hp 2-speed pump (new in 2014), Pentair Clean and Clear Plus Cartridge Filter (new in 2015), Pentair IntelliChlor IC40 (new in 2016), new Raypak RP2100 propane heater (installed 4/2013), Mayfair Dolphin Supreme 4 cleaner, 3 jets, 1 floor drain, 1 Polaris jet (never used), 2 skimmers, new Garrett liner (installed 4/2012)
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Opened Pool Today, Heater Drain Plug is leaking like crazy
    Yes looks like you are missing the o-ring. Here is what the plug should look like.Attachment 37258
    It probably came off and was washed away when they took it out. YOu should be able to find something very close at one of the big box home improvement stores.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
