Thread: New return on remodel question
    I am getting my pool In ground pool refinished soon and want to add an additional return. The area I want to add it to is below a concrete deck, so my question is in looking at parts for a new return most have a big plastic nut or fastner that you have to secure from the back of the pool concrete/Gunite. Can a hole be drilled from the empty pool and a new return be put in without fastening the end from outside from below the deck with just Hydralic cement or epoxy only without the rear fastened?
    The pipe can be pushed through based on the yard grade by digging a hole 10 feet or so down from the yard in the grass to get the piping to connect to the new plumbing line.
    Thank you for any advise.
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    Jun 2014
    15,093
    Re: New return on remodel question
    Roth79, it appears you haven't received a reply yet on your post about a new return. Not sure if you have resolved your issue by now, but this reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. We apologize for the delay, and thank you for checking-in with TFP. Have a great day.
    Thanks Tex no I didn't but I think it's just Hydralic cement from the inside of the pool.
    Thanks
