Results 1 to 15 of 15
Thread: Store says Increase CH in vinyl pool
    May 2015
    Sheridan AR
    2
    I have a vinyl pool my calcium hardness is only 70 I am being told to raise it because ideal 200 -400 and min.is 100 . they say if you don't it will eat up my ladders and any parts of metal in the pool is that correct. can anyone give the truth.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Store says Increase CH in vinyl pool
    Quote Originally Posted by brundel View Post
    For vinyl pools, CH is largely irrelevant. 50 to 350 is fine for a vinyl pool, even higher is fine too. Lies, lies and ****ed lies. No reason to raise your CH.
    Isolated Spa - 345 Gallons
    38,475
    They do not know what they are talking about. Your CH is fine.
    JoyfulNoise's Avatar
    May 2015
    13,247
    Calcium hardness and the various saturation indices that are calculated using CH values (CSI and LSI) have absolutely nothing to do with metal corrosion. See this thread for a very detailed discussion. This is the money-quote (emphasis and abridgment added for brevity) -
    These indices do nothing more than predict saturation of the water with calcium carbonate...... These indices do not predict metal corrosion whatsoever. When one refers to water being "corrosive" in terms of these indices, it is only in reference to the dissolving of calcium carbonate as a component of plaster (plaster is mostly calcium oxide in a hydrated silicate).
    So the Pool Store is telling you a bunch of baloney about corrosion. And, as stated in the many replies, your CH is absolutely fine for a vinyl pool.
    Last edited by JoyfulNoise; 05-29-2015 at 05:14 PM. Reason: shortening quote and typos
    Matt
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Supporting what the other responders have stated...
    Your CH is fine - no need to adjust it.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I concur with the other. My recommendation would be to buy your own recomended test kit and stay away from the pool store.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    22,553
    I've had zero ch for 5 years and have had absolutely no problems. I started it as a test, and I think 5 years is a pretty good test.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    hummm... I trying to thing of something of something brilliant or dazzling to say, but its Saturday morning and I have to think too hard at work, so Im taking a break on thinking.
    So, in regard to your vinyl pool needing CH, I will just say 'hogwash'!
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Too bad you're so far away. You could come over with an empty bucket and get some of my pool water and raise the CH in your pool for free.
    It might be interesting to note that auto manufacturers prefer there be no Calcium in the radiator coolant. And they deal with interesting combinations of iron, steel, brass, copper, and aluminum.
    The pool store clerk is just following the preprinted guidelines. You need Calcium because people with plaster pools need Calcium and the pool store needs the sale.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That is hilarious!
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2014
    Shallotte, NC
    693
    I added calcium to my liner pool. Fill water was CH 20, so when water was balanced I still had a CSI of -1.11. The quoted article seems to discuss positive CSI values. I understand the need for calcium in a plaster pool, however, I had believed that the CSI was of some value when considering a vinyl pool and associated hardware. Is that not the case?
    38,475
    You can not leech calcium out of vinyl, so low CSI does not matter.
    Aug 2014
    Shallotte, NC
    693
    OK, got that, but maybe I need to ask this question, instead: "Is there any index to describe the aggressiveness of pool water towards metals, such as those found in pumps, filters, heaters, etc?"
    May 2015
    13,247
    Quote Originally Posted by ewkearns View Post
    See the link in my previous post. That thread has a detailed discussion of different indices and has some web links to external sites on corrosion of metal.
    Problem with metal corrosion indices is that they are specific to different metals and their alloys and usually require the measurement of dissolved oxygen, sulfur compounds and other chemicals that one does not typically test for in pool water. They are also typically specific to closed water systems (steam boilers etc) and not open systems like pools.
    Matt
    Jul 2014
    NJ
    123
    Don't believe the pool store. I had this exact same issue too. I now have a bucket of CH that just sits there.
    20x40 L-shape 35k gallons, Pentair FNS 60 SQFT DE Filter, Pentair Multi-port Valve, Hayward Super Pump w/1 glorious HP, Vinyl Liner, Dolphin Z5, TF-100 w/Speed Stir
