Thread: Leveling ground
    May 2015
    Tuolumne CA
    2
    Leveling ground
    Putting up a 16x48 and the area is hard packed rock and gravel. Is there an easier way to level the ground without digging it all up?
    38,475
    Re: Leveling ground
    Welcome to TFP!!!
    The pool should be level to within 1" and you should dig down the high side. Unless you have the equipment and know how to properly pack anything you build up.
    May 2015
    Tuolumne CA
    2
    Re: Leveling ground
    Thanks, just a pain in the butt trying to dig out the hard pack rock and gravel.
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: Leveling ground
    Rent a jackhammer, that's what I did. And, yes, definitely dig down to level. You will thank yourself
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    Re: Leveling ground
    Here's my solution for my 16x48. Been up 4 years now, with no problems.
    Dimension at the ground for Intex 16' Ultra frame pool.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2014
    Oakbank, Canada
    389
    Re: Leveling ground
    I did that as well for the first 4 years, no problems.
    Quote Originally Posted by jeffchap View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
