Thread: Battery powered vacuum for spa
    Apr 2012
    Newton, NC
    173
    We have a Polaris robotic cleaner for our pool, and we purchased the Aqua Broom battery-powered vacuum for our spa. The Aqua Broom has poor suction, and can be nearly impossible to turn on/off.
    I would like to find a more powerful battery-powered vacuum. From my searching, it seems that Watertech is the only company to make battery-powered vacuums. I have been looking at the Catfish and Pool Blaster Max as possibilities. The reviews on these vacuums are all over the map....many people seem to love them and just about as many people hate them.
    Has anyone here had good experience with battery-powered vacuums?
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Battery powered vacuum for spa
    I have a Pool Master Blast that works great. I also orderd the fine silt bag.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    We're on our second Pool Blaster Max. Even though the first died after a year we still love the ease of using it on the small bits of schmutz in our pool and spa.
    Apr 2014
    Manitoba, Canada
    70
    We just purchased a Pool Blaster Eclipse today. We have seen some positive reviews, so figured it was worth a shot. We had removed almost all of the heavier debris from the pool bottom with our regular vacuum over the past couple evenings (but have quickly tired of fighting with hoses and having to replace all the water we lost in the process of course). Most of what remains, now, is fine silt and sand, that has settled onto the bottom of our crystal clear pool. We wanted something that would suffice for such a (small) job. We have it plugged in for its initial charge, so fingers crossed when we fire it up in the morning that it performs as well as we hope
    Our "Backyard Oasis" 2014 12x24x52" Steel Pro Hydro Force (Bestway) 7725 gallons; Jacuzzi 1LRC-5-S1/B 1HP Pump: Jacuzzi L192-7C 19" Laser Series Sand Filter; KStar 10 10KW Electric Pool/ Spa Heater; Jacuzzi wall mounted skimmer
    Apr 2012
    Newton, NC
    173
    After doing some more research and the feedback from all of you, I decided to go with the Pool Blaster Max. We received it last Monday and have used it a few times. Definitely much more powerful than the Aqua Broom, and it has a large filter bag that holds the crud when you take it out of the spa. We'll use it in our pool to just pick up small bits of crud, but its primary use will be the spa. We did the spa in about 25% of the time it took with the Aqua Broom. As long as the rechargeable battery provides a long life of recharges, I think this will be an excellent tool for cleaning the spa.
    Vince L
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Glad you lopike it! I use mine about every 3 days unless the wind blows a lot it in.
    Lisa
