Results 1 to 8 of 8
Thread: How to measure chlorine levels of 15-20 ppm for shocking with bleach
    Aug 2014
    Richardson, Texas
    1
    I have a healthy crop of green algae in my 18,000 gallon plaster pool. I want to use bleach to shock. I've measured the CYA at 50, which according to the TFP table requires a chlorine level of 20 ppm. My Taylor test kit only reads levels up 5 ppm. How do you measure higher levels of chlorine?
    38,242
    Re: How to measure chlorine levels of 15-20 ppm for shocking with bleach
    Welcome to TFP!!!
    You need to have one of the Recommended Test Kits that includes the very critical FAS-DPD Chlorine Test.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Mar 2015
    Baton Rouge, Louisiana
    92
    You could calculate a dose of to reach the minimum shock level of 20ppm pretty easily with the pool math application. It won't stay at 20 long though with a growing crop of algae. The test kits are helpful, but at the start of your SLAM you will be chasing to keep chlorine above minimum SLAM level. Do you have any other issues? Leaves, dirt, etc?
    26000 gallon Kidney shaped gunite pool. Older pool with deep dive well, nice diving board and tall slide. 31" Hayward pro sand filter with Pentair 1.5hp pump. Testing with the TF-100 plus test kit. Using a Dolphin Nautilus pool cleaner robot, next to bleach, my pools best friend.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The FAS-DPD Chlorine Test is required for the SLAM - no way around it.
    You can help speed up the SLAM process by manually removing any debris (leaves, branches, dirt, etc.) from the pool.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    The test kit is a must. It is easy to use and reads higher levels and more accurately than many other types of tests.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Trying to perform the SLAM procedure without the FAS-DPD chlorine test is a bit like driving a car blindfolded, you may get where you are going, but there are likely to be a few bumps along the way and some unexplained dings when you get there.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    You can buy the fas/dpd test as a separate component rather than a whole new kit depending on which Taylor kit you have. You may have the kit that has everything but the right chlorine test.
    TFTestkits.net
    Which Taylor kit do you have?
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    If you have the Taylor K2005, then you are good with getting only the FAS-DPD,
    if however you only have the Taylor K1000 which only measures FC to 5 and pH, and depending on the pool store to measure your CYA, then it would be best to replace the test kit you have, so that you can measure CYA, as well as all other water parmeters yourself.
    Divin Dave,
