Results 1 to 20 of 20
Thread: 2 speed pump wiring
    tcat's Avatar
    May 2012
    Austin, TX
    731
    2 speed pump wiring
    I currently have my pump wired to a t104 timer. Also have a Steiner pump wired to a second t104. I have a manual switch to switch from high to low.
    It's there a way to run the pump on high for the 2 hour period I run the Steiner (both on the second timer), with low speed running on the 1st timer?
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    38,290
    Re: 2 speed pump wiring
    Not really ... because you have to be sure you do not supply power to the high and low speed lines at the same time.
    May 2009
    Youngsville NC
    395
    You need a more sophisticated setup than you can do with your existing timers is what jbizzle is saying.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    38,290
    I think you would need a T106 instead of one of the T104. The T106 is a SPDT switch that could switch the speeds.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I just found this, so it looks like if I replace one t104 with a t106, I could run on high for 2 hours, and also have the Steiner on the same high circuit.
    How To Install a 2-Speed Motor and a T106 Timer - INYOPools.com
    DIY chlorine feed
    BBB
    38,290
    Whataya searchin outside TFP for
    Yup the T106 is what you need.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Thanks. Ordered a t106 to replace my 104. Will be nice to have pump come on low at 9am, switch to high at 11am and back to low at 1pm, all off at 8pm. With Stenner running from 11-1. Looks pretty easy to rewire.
    DIY chlorine feed
    BBB
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Need some quick help. I have my T104 and T106 wired for 2 speed pump operation and Stenner running on high. I have 2 red and 2 black wires (1 each from the freeze protection, 1 ea from L1 and L2), where do I connect them?
    Edit: I have the T104 and T106 wired like this: http://waterheatertimer.org/images/H...mp-7-large.jpg
    Pump works on hi and low, Stenner comes on during high speed. I disconnected the freeze protection until I know where its wires go. I have 3 red and 3 black from it (I can remove its cover if I need to know where these come from). Can someone tell me which terminals (on T104 and/or T106) each wire goes to using the above diagram?
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    Looks to me 1&3 from L1 and L2. Your feed for the time clock. Now the red and black for freeze protection looks to me it feeds the controller so they would go to 1&3 also to the T104.
    The T106 is just for the two speed pump. T104 is your timer.
    Give me more info on that freeze protection controller. Model number/ manufacturer
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I believe it is: https://www.1000bulbs.com/pdf/Inter-...-Operating.pdf
    Came with two T104's, changed out one with a T106 to get the 2 speed switching. Just not sure about the 6 freeze guard leads, since on page 4 some leads are going to both timers.
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    Possibly those extra leads are for auxiliary equip. like a spa.......looks to me everything in that controller come factory wired so all you have to do is follow the lines on the diagram. Line in (feed 240v) and load (pumps). Only difference is you put a t106 for 2 speed pump.
    Just follow the diagram
    tcat's Avatar
    May 2012
    Austin, TX
    731
    The diagram is 2 t104 timers. I can follow the 2 lines to L1 and L2 for 240v, but the other 4 wires go to terminals 2&4 on left, and 1&3 on right. Seems they should all go to the t104 (somehow).
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    The black n yellow are your high n low speeds n go to t106. The other white n green from motor go to t104. The green goes to ground bar
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Where are you getting the colors? You're talking from the freeze relay, right?
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    No the black yellow white green coming off your Hayward motor going to the T106 time clock. Black n yellow are your high n low speeds. You replaced one of the T104 with a T106 correct?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Yes, I have the pump wired correctly and works fine per this diagram: http://www.inyopools.com/howtoimages...g&maxwidth=800
    It's the wires from the freeze relay I need to figure out.
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    As far as the relay goes it says it's factory wired. If not u need a more detailed diagram of the relay from manufacturer
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Yeah, that's what I'm trying to find. It's this unit (pf1103m), has 6 wires coming out, but I can't find any diagrams with t104 and t106 timers.
    http://edc.poolsupplyworld.com/wimag...3m.jpg?500x500
    DIY chlorine feed
    BBB
    May 2009
    Trenton NJ
    497
    Looks like the thermostat for the freeze protection. All it is basically is a switch.
    Line n load but I'm surprised it doesn't come with a diagram. Sometimes they are on the cover of the panel or the device itself
  20. Back To Top    #20
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I emailed Intermatic, maybe they have a diagram.
    DIY chlorine feed
    BBB
