Results 1 to 8 of 8
Thread: Structural question
    cbrach411's Avatar
    May 2015
    Surprise, AZ
    108
    Structural question
    the guys that sprayed the shocrte on our baja shelf said it was missing 18 inches of steel would anyone see this as an issue?
    ( Under Construction) (May, 11th 2015 start date) 25' x 16' free-form, IG shotcrete, Blue Granite pebble sheen, travertine with stacked stone sheer descent, Hayward variable speed pump,
    May 2015
    Loomis, Ca
    17
    Re: Structural question
    I'm not an expert, but if there's no steel on the Baja shelf, how did they electrically bond that area? I have to assume it passed the Pre Gunite inspection. Also, in the overall build cost, steel is not that expensive. You're talking about $60 in steel.
    Owner Builder 15x32 sport pool. In process of building. Completing digging, plumbing, electrical, tile & equipment install myself, contracting out remaining.
    cbrach411's Avatar
    May 2015
    Surprise, AZ
    108
    It has steel on the shelf just not built out enough the steel was 18 inches short
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    That will not be an issue. The rebar is typically centered in 8-12 inches of gunite/shotcrete. Any additional that was placed on top of that is solely to achieve a shallower depth (much like your situation). Steps and seats in pools and spas rarely have (or need) any steel in them since these areas are not structural and are more for convenience/appearance.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Agreed, that it should be fine. Our bottom step is attached to the sun shelf and is probably 8' long has no rebar. It is all within and on a fully rebarred (made that word up) shell and floor.
    Jan 2015
    Phoenix, AZ
    638
    our Baja is 6 inches short on one of the walls of our Baja step. I wonder if it matters for a vertical wall? seems like it'd be easier for a horizontal plain. anyone remember how the shotcrete held in place? is it just thick enough concrete? or do they form it with boards?
    40' x 12' IG shotcrete (3 1/2' 5, 4'), Hayward variable spd pumpSP3400VSP, Paramount PV3 in-floor, venturi skimmer, 14,400 glns, Hayward Turbo salt cell T Cell-15, UV, Hayward DE filter, model DE4820, 2 Hayward Color Logic 320 LED color lights, Hayward P4 w puck. 2" line to in-floor valve (46'), deck mount canister parascoping fountain, leaf canister, Marbella, pebble. new build 6-24-15
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Shotcrete typically has a 2" slump which means it is a very dry mix and is nearly self supporting. In your situation they will most likely shoot the wall, let it set up for 30 mins or so, and then hit it again to bring it to the final thickness.
    -Brian-
    POOL BUILD
    Jan 2015
    Phoenix, AZ
    638
    thx bdavis466!
