Results 1 to 11 of 11
Thread: Raypack 156a help
    Raypack 156a help
    I just had my plumber run the gas to the heater. I have gas to the unit. When I turn the unit on it says timer/Fireman SW . Any ideas? Is it a safety feature because I do not have water running yet?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Re: Raypack 156a help
    No, the firemans loop on the heater board (red loop) is not looped any more. Or, it is hooked up, and if you have timeclocks, the time clock is about 15 min before or after the shut off time. If you have automation, yes no pump running/call for heat from the automation.
    Factory Warranty Station for:
    I removed the two red wires and it went away. Now its say Hi Limit 2 Fault. Is this because there is no water or filter attached?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Its none of my business but, why are you trying to turn on the heater with no water running through it?
    Quote Originally Posted by Pool Clown View Post
    I wanted to make sure it was working before the Plummer left. I am opening the pool tomorrow.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    wouldn't you want to run water through it too while the plumber was there?
    In theory that is what I should have done. He left his tools so I'm not worried about him not coming back. I'm assuming the falt I am getting is due to no water. I know there is gas because he tested it. Tomorrow when I open the pool I will test it out.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Here's a link to the manual to help you.
    Raypak 156 Manuals
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    thanks I am lost. The filter says 15 psi and that's what it said last summer so I am not losing any water pressure (or I don't think I am). I changed out the filter cartridge and nothing. I checked the pool and no water bubbles coming out of the jet and it is just as powerfull as last summer. Do I have a defective heater? Like I said today is the first time I turned the pool on. Do I need to run the filter for a period of time before I can use the heater? It still says Hi Limit 2 after I restarted the heater. Any suggestions would save me from throwing it over the fence lol jk...
    Semi above ground pool 12x16 raypak 156a heater
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Use the manual that Paul posted, locate the high limit, and confirm that the wires are connected properly. Also trace those wires back to the board, and confirm connection to the board. Didn't you post about a firemans switch error too? Sounds like something may be going on with the board or the plug connections.
    As someone with no experience with a heaters. Learned a lesson don't touch. I plugged in the wire back in which. I though was causing the first problem. And everything is working fine. Thanks
