Thread: Pour New Concrete Pad for Paver Install? Prevent Sinking?
    May 2015
    Cape Coral, Florida
    43
    One of the better pool builders that I've contacted to install my IGP, recommended that I install a 4" concrete slab before the paver installation. He said that all pavers will eventually sink. The only way to prevent them from sinking is pouring a 4" concrete slab and installing the pavers on top of the concrete. However, another pool builder said that doing this will create a mold and mildew issue because the pavers will not drain properly.
    Any suggestions would be great!
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Pour New Concrete Pad for Paver Install? Prevent Sinking?
    IMHO, putting concrete under pavers makes for an expensive deck.
    Pavers or Travertine is usually laid on a compacted base with a 6" layer of stabilized sand compacted on top, then topped with a little loose sand.
    After laying a polymer sand is swept into cracks and watered in.
    Inevitably, even with good preparation, you will get some pavers that will sink a little.
    This is easily fixed by poping out the pavers, breaking up the stabilized sand, recompacting and levelling, then re-lay pavers.
    This form of deck is very forgiving because you can come back later and lift it to lay an extra conduit under it for instance.
    Other than the cost of putting a deck under your deck, you had better put everything you could possible need in the ground under the slab, cause going back later is not pretty.
    Mold, mildew, first I have heard of that.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
