Results 1 to 7 of 7
Thread: Help with electrical wiring new dual speed pump
    hanesian's Avatar
    Jan 2013
    Eagan, Minnesota
    49
    Question Help with electrical wiring new dual speed pump
    I'm in the process of replacing my ancient single speed pump with a new dual speed one (Pentaire Superflo Dual Speed 1 HP). I'm good on the plumbing side and I'm pretty comfortable on the electrical, but would appreciate feedback/confirmation that my understanding & plan is correct, or suggested corrections. Here's the scoop.
    Both the old and the new pump are 230V, and the existing electrical to the pump looks like this: 4 lines - green, yellow and two blues, one of which has had the blue wrap removed to expose white casing, so I'll call it blue/white.
    Schematic on the existing pump:
    Pretty dirty inside, but here is the existing wiring: Green - ground, Yellow - A, Blue/white to B, and second blue not connected but just capped off with twist on connector.
    Now, moving on to the new pump. Following are shots of the new pump and schematic.
    And the toggle switch:
    1. Obviously the green is the ground, but I'm looking for reassurance that for 230 the yellow connects to terminal 1, and the blue/white to the middle black line on the switch. Is this correct?
    2. Is the 'extra' blue line there IF I wanted to wire it as 110V instead of 230V, but since I'm sticking with 230V it should continue to be unused/capped?
    3. Switch wiring: The yellow on the switch to terminal 2, and the white to terminal 3 or 4; and as stated above, the black on the switch to blue/white line.
    I hope I explained that clearly enough, but if not let me know and I'll try again!
    Thanks very much for any feedback!
    25,000 gallon, vinyl IG, Pentair Superflo 1 HP Dual Speed pump, Hayward S-240 sand filter, SWG, Raypak M206A heater, Polaris Pool Cleaner 280
    38,532
    Re: Help with electrical wiring new dual speed pump
    Sounds like you are correct
    Odd that there are 4 lines. You would still only need 3 for the 115V wiring.
    The 4 lines could have allowed you to run the 2 speeds from a remote toggle switch or by automation.
    hanesian's Avatar
    Jan 2013
    Eagan, Minnesota
    49
    Quote Originally Posted by hanesian View Post
    Can anyone tell me about the connector on the end of the black wire in the switch above? I can't seem to pop it off. Does that plastic end piece pry off, or do I just have to cut it off? Seems silly that it wouldn't come off.
    Jun 2012
    western NY
    1,562
    Are you certain the existing motor is hooked to a 240 volt circuit? Where do these wires come from, circuit breaker box or a junction box or an automation box? I ask, because the wiring seems to be a bit non-standard.
    Edit
    OK, just went back and looked at the old motor connections and see that it is wired as a 240 volt. The "cap" on the black wire looks like it will need to be cut off. Either of your hot leads can connect to the black switch wire and the other hot lead to the #1 terminal. The switch wiring is as you thought.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    hanesian's Avatar
    Jan 2013
    Eagan, Minnesota
    49
    Yes. Double circuit in breaker box. No question.
    Jun 2012
    western NY
    1,562
    Looks like we posted at the same time. I edited my previous post.
    hanesian's Avatar
    Jan 2013
    Eagan, Minnesota
    49
    Thanks for your help Jason and danpik. Pump installed and running!
