Results 1 to 11 of 11
Thread: New Opening Need Chemical Check
    May 2015
    Richmond, KY
    16
    Just opened pool (pool company did this). Left town for 1 week right after. Have test results. Can you tell me how we are doing and what we need to do? I think the CYA needs to be lowered, everything else "OK" but maybe not ideal. Signature should show details but since I am new:
    15,000 gal, 24' AG vinyl pool, Hayward Perflex Extended Cycle DE Filter; Hayward Power-Flo Matrix 1.5 HP Pump. Installed in 2012. Using TF-100 kit:
    FC 10
    CC 0
    TC 10
    Calcium 250 ppm
    Alkalinity 120
    CYA > 100 (approx. 120)
    Taylor's Kit CL 5; Ph 7.2
    Let me know if I am missing any info.
    Thanks!
    13,770 gal, AG pool-steel sides, vinyl, 24' round, Hayward Perflex Extended Cycle DE Filter, Hayward Power-Flo Matrix 1.5 HP, Type SP, TFT Test Kit-T100.
    38,267
    Re: New Opening Need Chemical Check
    Welcome to TFP!!!
    How did you estimate a CYA of 120ppm? The lines on the vial are logarithmic.
    You certainly need to replace at least half the water to lower the CYA level.
    Also remember the pH test is not valid when the FC > 10ppm.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not much to add at this point, so welcome to TFP!
    Enjoy your stay on the forum.
    Essential Links:
    May 2015
    Richmond, KY
    16
    Using the TF-100 Test Kit, the vial shows only up to 100....my results were in excess of that. So, I should drop my water level by half - even with a vinyl pool? Then retest? Thanks for the reminder about the PH level not valid if FC>10 ppm. Otherwise, looking ok?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    How does your water look?
    The numbers look good except the CYA. You do need to lower that and the only way is to remove and replace water. Use Pool Math to tell you how much. It is safe with a vinyl liner. Just do not go more than 50%. That might mean you need to do it twice but better safe than sorry.
    Let us know how it goes.
    Kim
    38,267
    Leave at least a foot of water in the shallow end to lower the risk to the liner.
    You may have to do it a couple times.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Howdy, howdy. If you are curious to know exactly what your CYA level is so you can roughly estimate how much water to replace, you can mix 50% distilled water with 50% pool water, perform the standard test, and then double the result. That will get you to a reading of 200 max. If your levels are still higher than that, well...you're in trouble. Good luck.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    38,267
    You do not even need distilled water ... just tap water.
    May 2015
    Richmond, KY
    16
    Quote Originally Posted by PoolESQ View Post
    The vial in the test kit only shows up to 100. I did the 50%/50% and black dot not visible at 80. So is my CYA 80 or possible 180? Yikes! Had the pool company check today and they showed 170 and told my husband that's not too bad, and the rain we are getting should help lower it...May be,,,but seems like it would take a WHOLE LOT of rain...and I do not live in an area that is getting super heavy rain/flooding. Help???
    NEVERMIND... I should have re-read the replies before I posted. so I double 70 - means my CYA is around 140,,,short of the 170 quoted by pool company. Still...............We plan to drop by 50%,,,,recheck and drop again if needed. Hate to take it lower and potentially damage liner.
    Quote Originally Posted by ksepurvis View Post
    May 2015
    Richmond, KY
    16
    I have dropped the water level by 50% and refilled. My CYA is now 80 (1/2 of what it was, yeahhhh). I think we will leave it there for now, maybe drop it again in late summer to "cool off the water"! Until then, if I keep FC around 10 it should be effective, correct? I have a whole big bucket of Tri-chlor, but I am thinking of selling it off at a yard sale, and move now to bleach!!! Thanks to all - I am sure I will be back!!!
    38,267
    Nice work! Just keep the FC above the minimum for that CYA level as shown in the FC/CYA chart in Pool School.
