Results 1 to 7 of 7
Thread: New owners- What's our next step, chlorine, salt...or something we're missing?
    May 2015
    Ankeny, IA
    5
    Hello,
    We just moved to a house with an AG SWG pool, never having had a pool in the past. We went to Leslie's Pool before we found TFP, they had us shock the pool to open and add some salt. The water is nice and clear, other than some leaves we need to vacuum. We added some chlorbrite yesterday because our FC was 0. We just tested this morning with these results:
    FC: 2.0
    CC: 0.5
    PH: 7.7
    TA: 100
    CYA: 80
    Salt: 2400
    CH: 1400
    temp: 70
    Should we just add salt then turn on the SWG or do we need to mess with the chlorine first? Should we add bleach and salt, can you add at the same time or should we wait 4 hrs between? We really don't know the next step and would appreciate any help from the voice of experience.
    Ankeny, IA
    24.2K gal AG, vinyl, cartridge filter, Ecomatic SWG, Dynamo 1.5HP pump, Heat Siphon DX5HP
    Jun 2014
    15,096
    Re: New owners- What's our next step, chlorine, salt...or something we're missing?
    Hello Cramorale! You are in the right place for pool care. But before we go any further, be advised you will hear this many times...... stay out of the pool store for chemicals (except liquid chlorine), advice, or testing. They will steer you in the wrong direction more times than not. First thing - you must order a TFP-recommended test kit of your own (i.e. TF-100 link below). That's absolutely critical. Once received, you might find that your results were much different than what they gave you above. Testing is not difficult to do. Also, start reading some of TFP's most common pages (links below) to get acquainted with the site and pool processes. Once you settle-in, you'll love it. Lots of people are here to assist. Congrats on your new home and pool.
    Oh, and for now, don't add anything to your pool except for bleach (liquid chlorine) as needed to augment your SWG to keep your FC at the recommended level. Others will chime-in soon.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,599
    Use bleach to get FC to 4 and keep it there. How much salt does your SWG require? Keep IT happy!
    May 2015
    Ankeny, IA
    5
    The SWG says at least 3000 ppm of salt and previous owner's said to keep it at 3500 ppm. We do have Taylor K-2006 and K-1766 test kits that the previous owners left. The results posted are our own from those test kits. We understand that we need to get the SWG running so it can start producing the chlorine. Can we add the bleach and salt at the same time? If not, what should we do first and how long before we can do the other?
    Ankeny, IA
    Jun 2014
    15,096
    Many SWG owners will augment their system with bleach, or even rely primarily on bleach during certain periods (i.e. SLAM) to save on the SWG.
    Apr 2010
    East Texas
    9,599
    Yes U can add both at same time. Let that new salt dissolve and circulate for a good while after making the addition before turning on the SWG.
    May 2015
    Ankeny, IA
    5
    Thank you both! We'll add the bleach and salt and retest tomorrow. Hopefully we're close to actually swimming.
    Ankeny, IA
