Thread: Is this an early version of a Jandy NeverLube valve?
    The Bing's Avatar
    Jul 2014
    Boston - South Shore, Massachusetts
    5
    The attached image is of one of the two 3-way diverter valves in my plumbing system. There are no identifying markings on it that I can find, so I cannot determine the manufacturer. My pool was built circa 1987. I am not the original owner and do not know if this is original equipment. Upon removing the eight screws, I see that the actual diverter face (panel?) has a square rubber gasket that has seen better days. I'm wondering if this is an early version of a Jandy NeverLube valve (it has a white body with black cover, handle, and guts)? If it is, is it possible to simply replace the cover, handle, and guts with same parts from a new valve, say a 4715 3-port NeverLube?
    Thanks
    22K gal, IG gunite, kidney shaped, built circa 1987. Hayward Sand Filter S244T with Vari-Flo XL multiport control valve. Hayward Super Pump 1.5 hp. TFTestkits TF-100. SpeedStir. The PoolCleaner 2x suction. Municipal water.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Is this an early version of a Jandy NeverLube valve?
    I think Jandy always label theirs as such.
    Zodiac Pool Systems
    Your best bet might be open it, take it to the pool store to compare the internals.
    The Bing's Avatar
    Jul 2014
    5
    Thanks for the suggestion, bobodaclown; makes sense. I do find it surprising that there are no identifying markings on this unit.
    Cheers
    The Bing's Avatar
    Jul 2014
    5
    The pool store turned out to be not very helpful. I self-diagnosed using info from this web site. Turns out that the valve is likely an older Hayward Dial-a-Flow 3-way valve, since Hayward valve seal part SPX0733E fits perfectly. I unscrewed the pads/paddles on both of my valves and replaced each seal with this part, used Teflon Magic Lube on the seals and the pads, and now the valves work as designed--no more seepage due to worn out seal.
