Results 1 to 14 of 14
Thread: Water is clear, chemicals are a mess can't fix
    May 2015
    Buffalo NY
    15
    New house to me with an in ground vinyl liner pool, 40,000 gallons. Opened it two weeks ago and water was clean and clear, I have a Hayward automatic chlorine and use 3" pucks. Took water to my pool supply store three times now results have not changed . Fcl .6 tcl .6 ph 6.4 alk 40 ch 150 was the figures yesterday. This is post 30 pounds alk plus, 15 pounds ph plus. I just added 2 gallons liquid chlorine and 5 boxes of borax. My current self test using the pro 7 kit is fcl 6.60 tcl 8.42 ph 6.5 alk 63 ch 56 cya 116 so far this clear water has cost me 200 plus and I can't seem to get any numbers to change to what's needed. Please help have a de filter that I back washed again today and recharged.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Water is clear, chemicals are a mess can't fix
    Welcome to the forum Realdealoo!
    You'll have some answers your way shortly. Good to have you with us.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP!
    My first suggestion in order for us to help you is that you need to get a recommended test kit such as the TF 100 linked in my signature or the Taylor K2006. You get more bang for your buck with the TF100.
    In Pool School please read through the ABC's of pool water chemestry and recommended
    levels.
    Pool School - Getting Started
    What does your water look like right now? You can post a pic by uploading it to photobucket then copy the IMG code and paste it here.
    Stay out of the pool store also. Do not buy anything from them except liquid chlorine.
    Don't add anything else to your pool other than liquid chlorine. Until you get your test kit.
    Use the pool math tab to figure out what to add. Your CYA is probably wrong, but you could do a partial water change to help lower it as it is too high.
    http://www.troublefreepool.com/calc.html
    Also remove the pucks as this is likely adding to your high CYA.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    30,432
    Welcome to the forum.
    Since your pH reads too low, you might consider raising it to the mid-7's. The problem is we have to assume that pH test is correct......my guess is it is because it came from different sources.
    Format your text next time you post so your numbers are easier to read. It's difficult right now.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Duraleigh. Question for you. OP says they added 5 boxes or borax already. Do yo think he should add more?
    Lisa
    Dec 2012
    Manassas Park, VA
    207
    For now lets assume that your test results are correct, however as stated above it is recommended that you get one of the recommended test kits.
    The first thing you should know is that the 3" pucks are most likely adjusting 3 different chemicals all at the same time.
    They are most likely increasing your FCL (like you want), however they are also most likely lowering your PH and raising your CYA.
    One of the great things about the methods taught on this site is that you want to adjust one chemical at a time (and know how it will impact your pool) or have complete understanding how the things you do add to your pool impact your pool chemistry.
    Also one of the most important things to understand is the relationship between CYA and FCL.
    Assuming that your CYA is correct and measures 116 you will want your FCL level to be above 7 at all times and preferrably at 12 at all times.
    A CYA of 116 is higher than is recommended, which is around 40 for a non salt pool. I would recommend doing a partial drain to bring your CYA levels closer to the recommended range, however if this is not an option you will want to add 2.5 gallons of 8.5% bleach to bring your FCl levels up to the recommended 12.
    Note 1: This is one of the reasons why the recommended test kit is needed as it can accurately measure fcl above 5.
    Note 2: The recommended CYA of 40 will give you a target FCL of 5 which the max most standard test kits can measure, but a SLAM level of fcl 16.
    Once you have gone through pool school and understand the chemistry of your pool and how to adjust each one individually you will have a much easier and cheaper time maintaining your pool.
    Hope this helps and please feel free to ask any questions you have.
    For example you can raise your PH by running the water feature such as waterfall if your pool has one instead of buying PH Up products.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    May 2015
    Buffalo NY
    15
    I'm currently doing home testing with a lamotte color Q pro 7. I'm unaware what digital unit the pool store uses. Currently the water looks great, very clear as it had been since I opened the pool. I will remove the puck chlorine, and go to liquid as recommended. The pool store test have all been the same and when I questioned the lack of change in ph, they also manually tested it so I believe the number to be accurate. I have had pools before and understand doing things one at a time. This pool just won't respond.
    Jun 2014
    15,270
    Realdeal008, you will find that many TFP'ers here would love nothing more to assist you to get those levels where they need to be. Even though you may feel the pool store and/or your current kit provide decent readings, the TFP experts have learned that is not the case. I learned the hard way as well, trying all of their products and gimmicks for months. Obtaining one of the kits recommended by the others above will make you a believer in not only how accurate YOUR testing will be, but provide you with lasting results and minimal maintenance saving you BIG $$$ down the road.
    May 2015
    Buffalo NY
    15
    Quote Originally Posted by Texas Splash View Post
    Sorry if I came across as knowing it all, wasn't my intention. I just wanted to describe what I was using currently. I will order the recommended kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You did not at all. No worries.
    Essential Links:
    May 2015
    minneapolis minnesota
    9
    Quote Originally Posted by Azgirl71 View Post
    Welcome to TFP!
    levels.
    Wow. I did not know that. I have using the Chlorine pucks for three years now. I suppose my pool is full of CYA- I have a 30,000 gallon one.
    There is no way to get rid of CYA except to replace the water- or remove enough to dilute it down.
    Or is there?
    30,000 gallon in-ground; cartridge filter; Hayward Super Pump; vinyl liner
    Jun 2014
    15,270
    Realdeal008, your replies were worded just fine. No worries at all. We're all poking-around on the site because we enjoy helping others the same way someone helped us when we first found TFP. Hope our tips and methods are productive and help you to have a happy swimming season. If you have any other questions .. just ask.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by steve53 View Post
    Or is there?
    No, unfortunately there is not. Don't feel alone, we have hundreds of new people every year that come here with that same issue.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    No other way really.
    Lisa
