Thread: New Pool Owner in Maryland
    May 2015
    Davidsonville, MD
    3
    Hi everyone. Just moved into a new (to me) home with a 32,500 in-ground gunite pool constructed in 1986. I am new to pool care so am very excited about TFP and all the great advice I have seen so far. I already have a question about a pool return fitting issue that I will post in the equipment forum.
    DHPool
    32,500 gallon in-ground gunite
    Constructed in 1986
    DE Filter
    Polaris 280 w/booster pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New Pool Owner in Maryland
    Excellent! We will be glad to help if at all possible.
    Welcome to TFP, and enjoy the forum.
    Essential Links:
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Welcome. Just a suggestion that you get ahead of the game and order the TF-100 test kit that is linked at the bottom of Patrick_B's signature. It will be required if you want solid help from folks here with your water chemistry.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP! Dittos on ordering one of the Recommended Test Kits. I use the TF-100.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP! Congrats on the new pool, we love ours!
