Thread: Intelliflow VF 11012 Pump - Feature GPM Setup Help
    I have new pump installed and am trying to set it up as follows
    Time Flow Purpose
    1am - 1pm 17gpm filtering / SWG
    1pm - 5pm 35gpm Additional purpose - Increase flow so
    heat pump kicks on and heats pool if required
    5pm - 6pm 50gpm Additional purpose - Increase flow for better skimming
    6pm - 11pm 17gpm Elimates heater
    11pm - 1am 0gpm 2 hours no pumping
    So I setup up the filter to filter from 1am until 11pm. Then I setup features (starting with 3) to change the flow as decribed. Tried it last night and the when the pump was supposed to pump at 50 the display showed it was pumping only at 31 gallons instead.
    I am pretty good with technology so I am pretty sure i set it up correctly. But based on the results I guess I am not as good as i thought. Is there something I am missing? Any help will be appreciated.
    Thanks.
    2008 23K IG Liner, Pentair intellipump vf, 48DE filter, Heatpump, SWC, aquabot turbo T, K2006 Testkit
    Re: Intelliflow VF 11012 Pump - Feature GPM Setup Help
    Reset the pump and started over. Works fine now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,459
    Nice! You are good with technology! I love my VS pump!
