Results 1 to 7 of 7
Thread: didnt follow thru complete slam
    Apr 2015
    china grove,nc
    71
    well I was so burnt out on purchasing bleach and going thru so much that I ended my slam to early it appears.. I ended my slam once I had no cc's and was holding a fc for a change, after 100+ gallons of bleach and other shocks
    correct me if I am wrong here but I believe I may still have some gremlins, I feel that I have to keep my swg on a lot high setting then I should for the run time and cya (70)levels, I have been running it on 50% for 14 hours daily(7am-9pm) and only getting 6-8ppm fc with no cc's, so I increased the swg yesterday to 75% to see if it would increase the fc and it went up to 9fc when I checked it, this is also with no swimming during the week. my pool is roughly 22k gallons and the swg is rated for 45k, so the reasoning for believing I may of stopped the slam to soon and question is, I checked my fc yesterday afternoon at 7pm and got a reading of 9fc with no cc, turned the pump on at 630am this morning to check fc and got 6fc so I believe I am losing to much fc and something is eating it, water is clear and beautiful as it has been since opened... so I lost 3fc overnight, but I also checked it this morning with out the pump running, could this cause the lower reading?
    if I start a slam again and finally get it where I lose 1 or less fc overnight with the day time ch demand be less?
    full test results 5/26
    fc7
    cc0
    ph 7.2
    ta100
    cya70
    tested Sunday before and ph was 8.0 so I added ma to lower it down
    sj45 swg, tf-100 test kit, 16x32 ig 22,000 gal vinyl, Dolphin nautilus plus
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: didnt follow thru complete slam
    Sorry you were burnt out. You do need to SLAM again until all criteria are passed. I know it is hard to be patient. Turn your SWG off for the SLAM and save your cell.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yup, ending a SLAM early leaves "gremlins" in the water and they rear their ugly head at the worst time. If there is still algae growing it will slowly overtake what your SWCG can produce and then take over the pool
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    It seems quite common that when the water is crystal clear but yet it still eats a bunch of chlorine, that something is still in there. And frequently, it's a mess of goo behind the pool light or beneath ladder steps or inside ladder uprights or down in the main drain well. So... check those things out. And run everything you have - drains, spas, waterfalls, whatever. You want the high-chlorine-level water everywhere. Also check for organic debris is the leaf basket. Maybe even in the filter. That will use a lot of bleach even if it isn't algae. It's still in the water, even if it isn't visible in the pool. You already passed two of the three SLAM tests, so cleaning everything out and blasting it again could make this SLAM very brief.
    Apr 2015
    china grove,nc
    71
    I did change my pool light bulb a few weeks ago and all kinda of nasty came out behind it, I left it out for 3-4 days and brushed it all out before reinstalling it...
    will work on slamming it again this weekend and see if I can get some better control of holding fc and hopefully be able to decrease pump time and swg %
    Apr 2015
    china grove,nc
    71
    Started the re slam last night. Got the fc up to 31 and keeping it going so far today without going below. So much nicer only having to add a gallon vs 10 gallons every few hours lol.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Glad you got started again. Keep us posted and ask questions if you have any.
    Lisa
