Thread: Sungrabber Solar heater Hook up with a GL-235
    eblade21's Avatar
    Jun 2014
    Lynbrook, NY
    23
    Hi all
    Great Forum
    Can someone please help me answer some questions.
    I ordered a set Sungrabber (FAFCO) Solar collector 2 x 2' by 12', these are being mounted on the roof facing south. I also ordered a Aqua Solar GL-235 controller. In the meantime i added a separate filter pump 1/2 HP 2500 GPH pump that will be controlled by the GL-235 I have included some pictures. I also started the hard plumb, I also added a sprinkler to cool down the water on hot hot summer days.
    [IMG][/IMG]
    [IMG][/IMG]
    I have attached a picture of the setup recommended; according to the sungrabber manual altered the diagram to fit what i think would work for myself.
    [IMG][/IMG]
    Still wasn't convinced I reached out to Fafco directly and they supplied me a different diagram setup
    [IMG][/IMG]
    Can someone please assist
    1. Which diagram/setup should i use?
    2. I like to install a pressure gauge being the pump does not have one, and i don't want to blow this solar panels off my roof, where in the setup would i install it to measure pressure.
    Please help me
    Eddie
    Summer Escapes 14' Pro-Series 4047 gallons; Intex 12 inch Sand Filter Pump; Intex SWCG; Vinyl Works Fence; Taylor K-2006C and Taylor K-1766, Intex 14 Inch Sand Filter Pump
    Sungrabber 4 x 12 feet Solar Collector controlled by Hayward Aqua Solar GL-235
    12 mil Clear Solar Blanket on SolarRoller; Aquabot Reaction
    eblade21's Avatar
    Jun 2014
    Lynbrook, NY
    23
    Re: Sungrabber Solar heater Hook up with a GL-235
    I tried to supply all the information necessary for a answer, but if anyone needs or has more questions go ahead, i will be pleased to answer to find a solution for this.
    Eddie
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The second diagram is the more advanced correct one, for best solar panel measurement the gauge should be installed at the inlet side of the panels, however to make life easier, you could install just after the check valve, then mathematically compensate for the height of the panel if roof mounted (water adds 14.7 psi about every 33 ft of height of water column).
    There is one more thing you need to add that is left out of their diagram, that is a vacuum breaker valve at roof level on the feed side to allow the panels to drain and not get overheated if the pump is off.
    eblade21's Avatar
    Jun 2014
    Lynbrook, NY
    23
    Isaac-1
    Thank you so much for your feedback and great answer.
    I like the second one also, felt less valves i have to control the better.
    I do have the sungrabber/fafco vacuum breaker, i did forget to add to the diagram, because i am, trying to figure out the best way to add this.
    Eddie
    eblade21's Avatar
    Jun 2014
    Lynbrook, NY
    23
    What do you think of this setup for the roof would you recommend.
    [IMG][/IMG]
    [IMG][/IMG]
    Eddie
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would go with the first one, remember to slant it at a slight angle so the water is always going up, otherwise you will trap air bubbles.
    Ike
    ps I will not be online much the next 4 days or so, taking a weekend roadtrip
