Results 1 to 9 of 9
Thread: Adding CYA
    Feb 2015
    North Alabama
    58
    Adding CYA
    I need to add CYA to my pool. I've read about both methods - hanging a sock in front of a return, or mixing it in a bucket of water and adding it to the skimmer basket.
    Questions:
    1) When they say to add it to the basket, is this the skimmer basket by the side of the pool, or the basket next to the sand filter?
    2) Do I need to run the pump continuously with either of these methods? Or can I leave the pump on its regular 12 hrs/day setting?
    3) Will raising CYA bind the FC that's currently in the pool? Do I need to turn up my SWG output % while I'm adding the CYA, to be safe?
    4) Is 80 a good goal for CYA in my salt pool, or should I start lower around 60? The pool looks great right now despite the low CYA level, so I don't want to risk messing up the other levels.
    Current levels:
    FC 5
    pH 7.5
    TA 100
    CH 50
    CYA 20 or 30
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Adding CYA
    Quote Originally Posted by wal81 View Post
    Questions:
    Side of the pool
    If it stays in, you need to keep the water flowing. CYA is acidic, and if it just sits and stews, it could etch things. In a sock, you can pull it out when the pump is off and set it in a bucket or tie it to a float and let it bob around.
    Most likely, your FC will raise as the CYA dissolves and gets dispersed, because you will lose less to the sun. I expect that in a couple days you'll be turning the SWG% down or reducing the pump run time. Just as an aside, most of us get by with three or four hours a day.
    Current levels:
    FC 5
    pH 7.5
    TA 100
    CH 50
    CYA 20 or 30
    Plug 30 in Now and 60 as target, just in case your testing is off a bit. In a week, test again and add more if you need it. It's easy to add more. It's hard to lose excess.
    Feb 2015
    North Alabama
    58
    Re: Adding CYA
    Thanks Richard. That was so helpful. Do you have a preference of the sock method vs skimmer? I don't live at the house full time right now - I'm just checking on the pool a few times a week. Not sure which route would be simplest in this case.
    Polaris 280
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,037
    Re: Adding CYA
    There is no versus. Use a sock no matter where you put it. Is there an old floating tab chlorinator? Try this
    Feb 2015
    The Woodlands TX
    46
    Re: Adding CYA
    This probably seems like a stupid question, but what do you do with the sock after dispensing your CYA? Does it go in the laundry with the rest of the dirty socks, or does CYA not mix well in a washer?
    Chuckling is allowed while reading this question.
    12,000, IG 1992, 4.5' center/3' each end, Pentair FNS-60 DE Filter (2015)
    PebbleSheen installed 2015
    Pentair Superflo VS installed May 2016
    TF-100 Test Kit
    Dolphin Nautilus Plus Robot
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Adding CYA
    I just put it back on.....................
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Adding CYA
    LOL! The sock I use is a mismatch from one of my kids so it hangs out with my pool stuff. It would be fine to wash it and put it back into circulation. Or give it to Woody for his other foot!
    Feb 2015
    The Woodlands TX
    46
    Re: Adding CYA
    Ha! I knew this question would bring me a laugh!
    TF-100 Test Kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,520
    Re: Adding CYA
    Richard,
    I bet you don't any problems with bulls getting in your pool...
