Results 1 to 13 of 13
Thread: testing errors - Can OCL be 0 ?
    I have recently had some ridiculous test results.
    I am not one that cannot follow directions. I know that I am doing the tests correctly (with corrective council from this site)
    I recently ran out of DPD powder and got some new. Don't know if that is relevant but I had no problems before that.
    Started getting cloudy water (perhaps due to laziness in not brushing and vacuuming) and I started getting impossible FC readings (increasing FC without adding any)
    Started shocking day before yesterday (and brushing and vacuuming) and OCLT was been less than 1
    Pool still cloudy.
    Last night OCLT was 0.
    Is that possible or am I still getting screwy readings
    25,000 Gal In ground
    Ceramic Tiled
    FKAA (Municipal) Water
    Sand Filter
    ! Hp No Name Pump K2006 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: testing errors - Can OCL be 0 ?
    Something is definitely not right. FC does not spontaneously increase in a pool. The only way FC increases is when some is added.
    Quote Originally Posted by midijamm
    What are you using to "shock" with? Are you following the SLAM process? How old are the other reagents?
    May 2015
    Central Illinois
    41
    I had this exact problem and it turned out to be my 6 year old water collection bottle while looked clean had a chlorine demand. If I tested immediately it was higher than if the sample sat in the bottle for a short time. Maybe a long shot, but it is definitely a thing.
    Viking Maui 2300g fiberglass in ground pool in a screened room with polycarbonate roof. 45gpm pump with sand filter manually chlorinated. Entire pool water can cycle in 51 minutes. Jacuzzi 336g hot tub with ozonator, manually chlorinated. TF 100 test kit with speed stir. Fungi pronounced Fun Guy, I'm Jim
    shocking with 5.25% Home Depot bleach
    Following the SLAM process religiously.
    Using new Taylor K2006 kit and new Reagents.
    FC loss last night 0
    CC 0
    Maintaining 13 PPM
    water still cloudy
    greenish yellow dust on floor
    Ceramic Tiled
    Sand Filter
    38,262
    Well, could just be a filtration problem.
    Have you inspected and Deep Cleaned your Sand Filter?
    Or you could try to Add DE to your Sand Filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by midijamm View Post
    CC 0
    Maintaining 13 PPM
    water still cloudy
    What is your CYA?
    Support the site
    Been backwashing filter and adding the occasional DE supplement
    CYA is 34
    Water is slowly clearing
    Again,
    Is zero FC loss overnite possible
    Ceramic Tiled
    Sand Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Sure, if there is no organic material in the pool to consume chlorine. It doesn't seem likely with your description of what is happening with your pool right now. There are only three options I can think of. It is either true, test error or bad test reagent.
    May 2014
    Franklin, NC
    9,184
    CYA is 34
    Again,
    How are you testing to get a CYA of 34?? The K-2006 CYA test gives results in numbers that end in "0"
    Support the site
    Quote Originally Posted by tim5055 View Post
    The same way I would determine I was going 34 MPH on a speedometer that had numbers that end in 0. it is 4/10 of the way between 30 and 40
    Is that wrong?
    While on the subject of testing technique, When I am testing for FC, and I know I am going to put in 20+ drops, is it ok to put in 5 or 10 and then swirl?
    TIA to you all
    Ceramic Tiled
    Sand Filter
    May 2014
    Franklin, NC
    9,184
    Is that wrong?
    TIA to you all
    Yes, that is wrong. The scale on the tube is not linear like a speedometer. If you notice the distance between the different readings changes as you go up the tube. It is safest to chlorinate based on the next highest reading.
    You really should continually swirl. That is why most of us purchased a SpeedStir after our wrists began to hurt....
    Support the site
    DFW, TX
    24,468
    You really should continually swirl. That is what most of us purchased a SpeedStir after our wrists began to hurt....
    LOL, right!
    You really should continually swirl. That is why most of us purchased a SpeedStir after our wrists began to hurt....[/QUOTE]
    While I really respect and appreciate all the info you guys so graciously give, I am the consummate cynic and doubter so I did the FC test swirling drop by drop and then I did it again a bunch of drops at once….
    AND … Drum Roll!!!!
    You're right.
    Completely different result
    Ceramic Tiled
    Sand Filter
