Results 1 to 12 of 12
Thread: Do you keep your Pump Plug in the outlet 24/7
    Jul 2013
    Long Island, NY
    532
    This is my question. I have an outdoor GFCI outlet but I manually plug in and unplug the unit everyday. I know that the GFCI will shut off if it gets wet but my concern is we have a torrential rain, can't water get into the outlet and damage the insides? See pic, if it starts raining crazy water can get in between the plug and the outlet receptacle. Do most people leave theirs plugged in 24/7.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Jun 2013
    Buffalo, NY
    80
    Re: Do you keep your Pump Plug in the outlet 24/7
    Mine is plugged in all day every day.
    That is an outdoor box so the likelihood of getting water in there is much smaller. It would take a good driving rain to really soak that. Worst case, if a big storm is coming just unplug it and close the lid.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    Mid Missouri
    227
    The cover on that box is not rated to be "in use" while its raining, it seals when it's closed. Google "while in use" outlet cover, that's really what you want to keep it plugged in all the time.
    Can't say if you'll ever have a problem with what you got, just pointing you to what is technically proper.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    Jul 2013
    Long Island, NY
    532
    Ah I see, like a big clear plastic cover where the plug fits into.
    SWG: Intex CS8110
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Mine is plugged in every day 24/7 for 2 years now.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Mine is like yours and I only unplug it for hubby to use his smoker.
    I am probably going to get a plastic cover though.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    For the short term... is there some reason other than esthetics that you can't put a plastic bag over the post and plug?
    JoyfulNoise's Avatar
    May 2015
    13,170
    You should change that receptacle to a proper outdoor, in-use rated one. Even the really fancy metal ones with lock-out tabs are not that expensive and the installation is pretty easy. Just remember to de-energize the circuit at your main panel before attempting to make electrical changes.
    Matt
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    mine has been plugged in 24/7 for 3 years now
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    DaneCE's Avatar
    Jul 2011
    VA
    279
    I have my power outlet covered with a tiny roof.
    May 2015
    13,170
    Quote Originally Posted by DaneCE View Post
    That's awesome!!
    Matt
    Orlando, FL
    690
    24/7 covered with a plastic bag.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
