Results 1 to 17 of 17
Thread: Rain does affect pool chemistry
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Actually the rain is having a major affect on my pool. My new TFP method is called rain and drain. Every afternoon I drain 4 inches of water off. Every night it fills back up to the top of the flagstone. I've proably taken 20 inches off in the last 2 months. My numbers run all over the scale. I even put some tabs in the tube just to help with chlorine and bring cya back. Calcium is down again. but it still looks perfect. How is everyone else handling this?
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Re: Rain does affect pool chemistry
    Just realize that when you replace as much water as we have around here lately-----ain't no chemistry gonna stand up stable to that! NORMAL rain doesn't effect chemistry much at all. THIS----------ain't normal!
    I got Noah on speed dial for advice.
    Jun 2014
    15,198
    My pool has "runneth-over" more than once this spring, and till crystal clear. If anything, I just had to add some stabilizer.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    When you are tossing out 4" a day, every day, and replacing it with more rain....yea, that is going to have an effect.
    We've cried for years about being dry, but even out West, we are SICK of the rain. We want some summer weather!! We are pool owners for cryin out loud, so how about some fun in the sun for a change? It feels like England or Seattle all the time!
    We aren't getting it like the rest of the state, but my pool is staying brim full.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Having a roof over it helps
    Ike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    I've had almost 9" since October 1!
    May 2015
    DFW, Texas
    3
    Same here - 4 inches pumped overboard again this morning. I quit fooling around with the chemistry until the monsoon passes. Just trying to keep the big picture reasonable. A touch of chlorine and hang on.
    18000 Gal, In-ground, Plaster, Hayward DE6000 filter/Hayward RS1500 pump/EVSJ3 Motor, Polaris 360
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sad, are you sure you did not mean May 1, which would still be sad, but less so.
    Aug 2014
    Norman, OK
    4
    I had cya levels over 100 so I had drained my pool about 1/2 down (about 10k gallons). When I came home one day I shut the pump down and thought I would start the house up to refill it after dinner.
    When I checked on the pool after the downpour it was already overflowing.
    I'm ready for some sun.
    24K IG plaster pool with Hayward S310S sand filter, 2 pumps, skimmers only
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    If you call and get a busy signal, thats me on the phone with him!
    Quote Originally Posted by woodyp View Post
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Definitely NOT normal rain this spring. I have added CYA 3 times and I am low and added salt twice. The lake went from 13' down to 11' over and the dam has been wide open for a few weeks. I have algae growing on the ground below my pool overflow. I think I need to SLAM my yard!
    May 2012
    Dallas, Texas
    47
    I'm so happy to see some sun on the way to North Texas. My FC and pH levels have been holding well and pool is still clear despite draining several inches 4 or 5 times over the last couple of weeks. I'll be checking everything and adjusting tomorrow when the sun arrives.
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    Jul 2013
    Waxahachie, Tx.
    446
    I agree about the not normal rain. Glad I bought that sump pump last fall for the pool. It has been a life saver on keeping up with all the water. FC has been ok, just having to keep up with CYA and salt.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Glad that's over, all my numbers are good and back to swimming.
    DFW, TX
    24,502
    yes, hello
    Jul 2013
    Waxahachie, Tx.
    446
    Amen to sun. Now back to normal chemical care.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    This thread is making me happy to have an auto cover. Cover pump takes care of the rest
    On the retrospect, we, here on east coast been enjoying a much more dryer spring then usual. This week is actually a first serious thunderstorm/****ty weather/cold/down pouring week we've had in 2 months or so! Looks, you folks in Texas have attracted all the rain!
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
