Thread: Raise calcium level
    mwswenson49's Avatar
    May 2015
    Frankfort, IL
    2
    Raise calcium level
    Pool and spa were refinished with Krystalkrete in December 2014. Ca level was 121 on May 28th; added 50 # of Dowflake Xtra which raised Ca level to 147. Retested May 29th and Ca level is back to 123. Thoughts?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Raise calcium level
    Welcome to TFP.
    If you look through Pool School you will find information on our system of maintaining pools. The two I would point you to are:
    Pool School - Start-up New Plaster
    If you add more information about your pool to your signature it helps us understand your situation more and give recommendations more specific to your situation.
    Support the site
    May 2015
    Frankfort, IL
    2
    For some reason my "signature line" did not appear. Specifics are:
    Pool: 35K gal IG gunite / krystalkrete free form beach entry; Pentair 72 sq ft DE; Raypak 399K heater; inline PerformMax Saniking; 2 HP Emerson pump
    Spa: 800 gal IG gunite / krystalkrete; Purex 150 sq ft cartridge; Raypak 181K heater; 1.5 HP AO Smith pump
    Featrues: Spa waterfall to pool with control valve; pool infinity edge with sump pump for recircuclation
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by mwswenson49 View Post
    if you typed it the same way it might be too long. You need to abbreviate as you only get 5 lines.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    Thats a nice sized pool there, I was wondering about 50# of Calcium, but I see why now.
    Essential Links:
