Thread: Solar heater before or after salt chlorinator device ?
    I got this intex pool for the kids
    My set up is this.
    The water coming from the pool goes into the pump then it passes through the sand filter and then through a SolarArc Pro heater.
    Now i want to add a Salt chlorination system (intex salt system)
    Do i have to put the salt system before the solar heater or after ?
    I'm asking because i don't want to clog the solar heater with calcium deposit or even if it doesn'T clog, i don't want to build any calcium inside the heater panel ...
    The logic would say to put the Solar Heater Panel at the very end of everything (once the salty water turns into chlorine water...
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Solar heater before or after salt chlorinator device ?
    It needs to go pump-filter-heater-swg. If all your levels are within tfp recommended ranges, you won't have any calcium scaling in the heater.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
