Thread: Fix PVC going to Leaf Canister?
    May 2015
    Arizona
    1
    I have a underground pool and the PVC "nut" (i don't know what it is) cracked and is letting air into the pipes. When the filter turns off, air rushes in and all the water drains into the pool making it hard for the filter to start again. What is the best way to fix this cracked "nut" on this PVC union? I know when I was replacing the unions on the Salt Cell T15 you could buy replacement nuts that came in two parts and you screwed it together around the PVC so you don't have to cut everything apart and redo it all. Can this be done here? Any idea what this piece is called? As you can see in the pictures, there isn't much room with the PVC length to start cutting and replacing.
    As you can see, I tried gluing it together after it cracked but it isn't keeping the union tight enough together, allowing air to come in.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Fix PVC going to Leaf Canister?
    If you can identify the canister, you might be able to obtain a new nut and tailpiece. Then you just saw the pipe off at the valve and glue an external coupling and a reducer bushing to it and hope there's still room to fit that piece with the captive nut on there. If that canister can move back a bit, that would probably help.
    Mar 2011
    441
    A&A manufacturing makes it.
    20X40 30,000 gallon gunite pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    it took me awhile but here ya go
    here is there website
    Home | A and A Manufacturing | Pool Cleaning Products
    here is where you can order parts
    Shop A&A Leaf Vac Debris Canister & Parts | In Stock & Fast Shipping
    this is the union set you need
    A&A Manufacturing LeafVac Union Set # 553289
    and here is you manual, not much to it but it shows what it looks like underground
    http://www.aamfg.com/leafVac.php?content=manuals
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Once you cut the old one off, I would use a pipe extender, glues into the inside of the pipe, then put your tail piece on with the union. Brings you back to close the original length.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
