Thread: Another to Close or NOT close
    Jun 2007
    Springfield IL
    16
    Hi Guys: I always get good info here so I thought I would try again. I live in Central Illinois so we get some pretty cold winters yet I still wish to leave the pool open.
    I intend to:
    Install an outdoor thermostat to run the pump whenever the outside air is less than 35 degrees.
    Return equal water from skimmer and bottom drain.
    Supply equal water to all jets.
    Vacuum leaves from the pool as necessary all winter.
    Manually shock the pool with bleach all winter as necessary.
    Turn off the SWG.
    Remove my Cartridge filter.
    My Concern: The pool is gunite and I believe ice will form on the top of the water line. Should I be worried about damage to the gunite or surrounding concrete pool deck?
    Is there anything I am missing? I have never heard of anyone doing this around here. So, am I nuts/
    All comments are appreciated as we will sure miss the summer around here.
    BBB works for me!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Another to Close or NOT close
    I'd close. You will get very cold weather that will require 24/7 pump operation to avoid freezing. Any disruption in electrical service or a clog in your skimmer basket from leaves or even chunks of ice could result in thousands in damages. The ice will form on the surface whether you close or not.
    Feb 2008
    Charlotte NC
    44
    Another potential downside: If you're at all like me, there is a not-insignificant possibility that you will fall into your pool while cleaning out gunk in mid-winter . . . The one winter I didn't close our pool, I fell into 42 degree water - in Illinois, the water will probably be about 33. When that happened, I knew for sure that shock was a verb and not a noun . . .
    22,000 gal, IG vinyl, 3/4 hp pump, 300lb sand filter (switched from DE), converted from baquacil (thanks to Ben), BBB since 2004
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Quote Originally Posted by tcpiii
    ...The one winter I didn't close our pool, I fell into 42 degree water - in Illinois, the water will probably be about 33. When that happened, I knew for sure that shock was a verb and not a noun . . .
    great post!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
