Thread: Multiple Temperature Sensors iAqualink
    Jan 2012
    New Jersey
    18
    Is there a way to install 2 water temperature sensor on an iAqualink? Im looking to also read the outlet temperature of the heater.
    Thanks
    Chris
    27,000 Gallon Inground Gunite Pool with 150 sq ft tanning ledge. Jandy ProFlo pump, Jandy 400K LXi NG heater, Aqualink PDA w/ iAqualink. Polaris 280 cleaner.
    Re: Multiple Temperature Sensors iAqualink
    The iAqualink doesn't have any support for additional water temperature sensors. If you don't have a solar system you can sometimes repurpose the solar sensor connector. Often it is simpler to use a completely separate temperature sensor, one that is not connected to the iAqualink.
    Jan 2012
    New Jersey
    18
    Quote Originally Posted by JasonLion View Post
    Thanks
    Chris
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Use the air temp sensor. Just keep in mind that you will loose the freeze protection... well, you wont really loose it, it'll just come on too late.
    Factory Warranty Station for:
