Results 1 to 8 of 8
Thread: Bluetrol and Algatrol
    Apr 2015
    South Central PA
    297
    I was cleaning out the pool cabinet and found a bottle of Bluetrol and Algatrol...is there any place for this in the TFPC method or should I just get rid of it?
    Thanks
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Bluetrol and Algatrol
    Without looking them both up and determining their contents I can't say definitively, but I'm guessing not.
    From their names I'm guessing a clarifier and algecide.
    Support the site
    Apr 2015
    South Central PA
    297
    Thanks. I thought these were standard brand names- must just be the local pool shop names. Bluetrol is a clarifier- says it restores water sparkle for hazy water. It doesn't seem to list avtive ingredients. Algatrol is an algaecide - active ingredients: poly[oxyethlene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Algatrol is polyquat, which is a good algaecide. More useful as an algae preventer, chlorine is more effective to use during an algae outbreak. Full strength polyquat is 60%. See this post on how polyquat works:
    Polyquat algaecides: Mode of Action
    The bluetrol is useless for TFP, and won't ever be necessary to use in your pool.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Apr 2015
    South Central PA
    297
    Thanks!!
    Apr 2015
    South Central PA
    297
    One more question: if I keep up with the recommended FC for my CYA, I should not have an algae problem, correct?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    correct,
    but I would like to add that you have to start off Algae Free.
    If you currently have any alage, then a slam is in order to kill it, and after that, just maintain the FC/CYA.
    Quote Originally Posted by 440dodge440 View Post
    Divin Dave,
    Apr 2015
    South Central PA
    297
    Yes, I did a slam and I met the criteria, so I believe I'm algae free....Thanks for the help
