Thread: Vacuum Stuck in Skimmer Box
    May 2015
    Hackensack, NJ
    3
    Hi (username is a joke). Long story short, I attached my SkimVac vacuum plate in the skimmer box without the o-ring. It got stuck in there and the elbow joint broke off.
    I have the pump turned off, the pool runs with the basket on top of the plate, but I have to empty the basket super frequently. Tried Vaseline at pool store's suggestion, and worried about prying too hard and damaging skimmer box.
    Totally not sure what to do. At the point where I'm considering trying to cut the thing out.
    Casey's Avatar
    SW PA
    10,450
    Re: Vacuum Stuck in Skimmer Box
    Take pics so we can see what's going on.
    May 2015
    Hackensack, NJ
    3
    These good?
    The second picture is clearer - you can see the notches where the elbow joint previously locked in.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I think you can get a small pry bar in there/down the middle and pop it out.. maybe napa or advance has 1 of these type bars
    TEKTON 3346 Rolling Head Pry Bar Set, 4-Piece - - Amazon.com
    May 2015
    Hackensack, NJ
    3
    Will it damage the skimmer box if I pry too hard?
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Instead of prying on it, if you can get the head of one of those pry bars into the hole in the plate, you may be able to dislodge it by repeatedly pulling up sharply on the pry bar while catching the head on underside of the hole. The idea is to "hammer" the plate loose. Just be sure to keep your face clear in case it breaks loose suddenly.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
