Thread: In floor nozzles sticking up
    Sep 2009
    Tucson AZ
    121
    Had a battle with black algae this spring. Between heavy brushing and high chlorine, finally declared victory, but the down side is that suddenly 3 or 4 of my in floor cleaning nozzles (Parmount PV3 models) now stick up and won't drop back down or cycle no matter how many times I tap them down. Took all of them out and cleaned them, but they still stick up every time, like the dead black algae maybe gummed up the works. Any suggestions?
    16,000 gal in-ground Pebble-tec pool / Pebble-sheen spa. Jandy AquaPure 1400 SW Cl gen (SWG) system. In-floor cleaning system w/ Hayward EcoStar 2.0 HP VSP pump. Hayward 31" sand filter. 900 sq ft Heliocol solar panels (on roof) w/ separate 1 HP Pentair WhisperFlow single speed pump. Water feature with separate Hayward 0.85 HP VSP pump.
    22,553
    Re: In floor nozzles sticking up
    Pull them out and take them apart and clean and inspect them and the receptacle for any scratches and/or abrasions. You may find a piece of debris stuck to them or they may have a scratch that's keeping them from operating smoothly.
