Thread: Been great for a year but...................
    May 2014
    Dallas, Tx
    72
    Hi all, writing from just south of Dallas where is just started raining again but luckily no flooding in this area. I have been able to keep the pool chemistry pretty stable over the weeks but this morning my FC was 3.5 and I put in 2 gallons of 8.25 bleach which should have brought it up to 7.3. Just checked it and it is back at 3.5.
    The numbers a few minutes ago are;
    FC - 3.5 CC-0
    PH - 7.7
    TA - 70
    CH - 225
    CYA - 30
    Over the last two weeks I have seen light yellow staining twice on a couple of walls, brushed it and no return yet. The pool is clean of debris(consistently taking out leaves, flying ants, twigs etc, in this stormy weather). I have run the OCLT twice in the past two weeks and been less 1 ppm loss both times. Time to shock? More rain coming daily at least through Saturday. Based on information from TFP archives, I haven't panicked in the rain, just made adjustments daily to stay in range from the PoolMath numbers. Would appreciate any suggestions.
    Mike
    Pool is inground 20' x 40' 42000 gallon, rectangular plaster about 60 years old, replastered 2 years ago. Pentair VS Intelliflo pump, Pentair 420 Clean & Clear Plus Cartridge filter. Using K-2006 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Been great for a year but...................
    On those rare occasions we've had rain, I just up the FC a couple PPM to deal with whatever washed in.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    mbeck5, I'm with ya on this one - literally and figuratively. With all the rain, I've also upped the chlorine a bit. I'm keeping it in the 4-5 ppm range and my CYA is about what yours is. Odds are that the yellow staining you're seeing is runoff and/or washed out debris from the atmosphere. (pollen, dust, etc.). Just keep up with the chlorine and you'll be fine. In fact, you may want to check your CYA level when you get a chance. Normally rain has a negligible effect on water chemistry. However, with the abnormally high amount of rain we've had lately, your water could have been diluted enough to lower it. Worth checking to make sure.
    Right now, there's a line of storms between Ft. Worth and Abilene working its way east. We have a chance to check and top off the chlorine levels before it arrives.
    May 2014
    Dallas, Tx
    72
    Thanks guys, appreciate the responses. This morning's numbers are;
    FC - 4.0
    CC - 0
    PH - 7.7
    TA - 70
    CH - 250
    CYA - 40
    Looks like we may have a few days of sunshine at last!!
    Mike
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yeah! Need some pool days.
    That FC is a tad low, makes me worry. I would keep it more like 5-6 to be on the safe side. It is has to stay above the minimum at all times so algae won't grow, Chlorine CYA Chart
    May 2014
    Dallas, Tx
    72
    Will do. Thanks again pooldv!
    Mike
