Thread: Two Return Jets Not Working
    Jun 2010
    Toronto, Canada
    34
    I started opening my pool yesterday and after adding some water I turned on the filter and added chlorine to shock the pool. Today I went out and noticed that 2 of my 4 return jets are not pushing out any water. Specifically, the 2 return jets on the main stairs are working while the shallow end and deep end jets have no water coming out. I didn't check these two jets yesterday so I'm not sure if it was like that from the start or if this started sometime in the last 24 hours. I did backwash today when the filter pressure started to rise, but that didn't help any.
    Any advice on what my next steps should be. I've never had an issue with any of my return jets over the years.
    20,000 Gallons Inground Vinyl Pool, 1 skimmer, 1 floor drain, 4 return jets, 1 vacuum intake
    Hayward Vari-Flo XL sand filter (SM2506T), Hayward EZ Flow Pump (SP-3107X10), Emerson Pump Motor (EB228), Hayward Comfortzone NG Heater, Hayward Chlorinator (CL220)
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Two Return Jets Not Working
    Hello,
    Are there any valves that control flow to those jets? You might try turning off the pump, unscrewing the jet, and running water back through the line, it may be clogged.
    Can you provide any pictures?
    Jun 2010
    Toronto, Canada
    34
    Hi bobodaclown,
    Right before the water enters my pump/filter, there are the following three control valves:
    1) Skimmer
    2) Vacuum
    3) Drain
    My vacuum valve is off as I never use it. The Skimmer and Drain lines are pulling water in as I've tested each individually and the flow out the two returns at the stairs is quite strong. I actually blocked both these stair return Jets this weekend and still nothing came out of the other two returns.
    How do I run water back through the line? Would I just stick a hose into the Jet hole and turn it on or do I need something stronger like a shop-vac, compressor to push the water back using air?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Last time I saw a post about this type of issue it turned out to be collapsed flexPVC pipe. There is no way for debris to get into that line to clog it unless there was a catastrophic failure in the filter. The water in the return lines is coming from the filter.
    Jun 2010
    Toronto, Canada
    34
    I meant to post earlier, but I've been swamped with work. Anyway, I feel like an idiot as the issue ending up being a valve turned off on my return lines after the pump. I had never really paid attention to this area of my plumbing, but I have two main return branches after the pump/filter/heater. The first one leads to the stair return jets, but has no valve so the stairs will always have water pumping when the pump is running. The second leads to the shallow and deep ends return jets, but it has a shutoff valve. I guess last fall I turned this to the off position and forgot about it. I've never touched it before so I've added this to my opening /closing spreadsheet.
    bobodaclown,I now see you were asking about the return jets after the pump while I was thinking you meant before the pump. Thank you and everyone who responded here.
    Apr 2011
    Murrieta, CA
    2,360
    All's well that ends well.
